    Blue Balls
    39 Posts 17 Posters 6.6k Views 17 Watching
      SketchUpNoobie
      May I ask a serious question? Why would one model his bal-, er, ornaments so large. Seriously though. I would like to know what is the advantage to having larger-than-life models. Would someone please enlighten me. 🎉
      SketchUpNoobie: the complete noob in all things SketchUp.
      • soloS
        John, I jest, I shrunk the person.
          SketchUpNoobie
          So they are really about 2"-3" in diameter? Gotcha'. 😳
          • boofredlayB
            boofredlay
            Actually I did draw mine over 3 feet in diameter. I wanted to have a real smooth mesh and when you draw small objects sometimes SketchUp cannot fill in the polygons. Sometimes it is better to model large then scale it down, sometimes.
              SketchUpNoobie
              Ooooohhh K. Now I get it. Thanks.
              • mitcorbM
                mitcorb
                An unfortunate workaround in my opinion.
                Units are arbitrary measures.
                You could conceivably set inches at 100 times what Sketchup has it set. Same with metric.
                • olisheaO
                  olishea
                  cool eric, tinsel looks great! i think ball would look even better with a coloured mirror finish and a night-time city hdri. merry christmas!
                  lots of free ones here http://www.smartibl.com/sibl/archive.html
                  oli
                  • N
                    notareal
                    Eric, that tinsel is great. Maybe some "bold" material like http://www.thearender.com/forum/viewtopic.php?p=30463#p30463 could fit in scene too.
                    • boofredlayB
                      boofredlay
                      Wow, I never knew about those textures. Thanks.
                      • boofredlayB
                        boofredlay
                        As promised Here is the published tutorial
                        • troyhomeT
                          troyhome
                          Great project and very helpful tutorial!! thanks so much 😄
                          IOviz.com
                          SU Pro 2024 PC
                          • V
                            Vicspa
                            I followed your publication Boofredlay, eveythings works just fine except that the tops of my fur comes out pointy instead of square as your sample. where am I going wrong?
                            • boofredlayB
                              boofredlay
                              Nothing if you selected "fur_instance" in the "Make by Component" field. This makes the "blades" a component. Now all you have to do is edit that component and make it look like you want. In my case I just squared off the end and made the whole blade just one face.
                              • boofredlayB
                                boofredlay
                                As lovely as they are I would like to see SU output too, if possible?
                                Here you go Rich.
                                Here are some views, one with the whole setup and another with just one piece of garland along with the ball. I changed the background to red so it shows up better.
                                • 2 / 2
