    Blue Balls
    39 Posts 17 Posters 6.4k Views 17 Watching
      SketchUpNoobie
      Ooooohhh K. Now I get it. Thanks.
      SketchUpNoobie: the complete noob in all things SketchUp.
      • mitcorbM Offline
        mitcorb
        An unfortunate workaround in my opinion.
        Units are arbitrary measures.
        You could conceivably set inches at 100 times what Sketchup has it set. Same with metric.
        • olisheaO Offline
          olishea
          cool eric, tinsel looks great! i think ball would look even better with a coloured mirror finish and a night-time city hdri. merry christmas!
          lots of free ones here http://www.smartibl.com/sibl/archive.html
          oli
          • N Offline
            notareal
            Eric, that tinsel is great. Maybe some "bold" material like http://www.thearender.com/forum/viewtopic.php?p=30463#p30463 could fit in scene too.
            • boofredlayB Offline
              boofredlay
              Wow, I never knew about those textures. Thanks.
                boofredlay
                As promised Here is the published tutorial
                • troyhomeT Offline
                  troyhome
                  Great project and very helpful tutorial!! thanks so much 😄
                  IOviz.com
                  SU Pro 2024 PC
                  • V Offline
                    Vicspa
                    I followed your publication Boofredlay, eveythings works just fine except that the tops of my fur comes out pointy instead of square as your sample. where am I going wrong?
                      boofredlay
                      Nothing if you selected "fur_instance" in the "Make by Component" field. This makes the "blades" a component. Now all you have to do is edit that component and make it look like you want. In my case I just squared off the end and made the whole blade just one face.
                        boofredlay
                        As lovely as they are I would like to see SU output too, if possible?
                        Here you go Rich.
                        Here are some views, one with the whole setup and another with just one piece of garland along with the ball. I changed the background to red so it shows up better.
                        • 2 / 2
