    Make Group Shortcut
    5 Posts 3 Posters 1.2k Views 3 Watching
      Jim
      I want to make a Shortcut for Make Group, but there are 2 items in the Shortcuts dialog:
      Edit/Make Group
      Edit/Item/Make Group
      What is the difference in these?
        Edit/Item is the context menu.
        I think there might be a difference between them in that one will let you group individual entities, and the other require two or more.
        • mitcorbM Offline
          mitcorb
          Question:
          Edit/Item/Make Group must be part of SU8? Don't see it in 7.xxx
            Jim
            @mitcorb said:
            Question:
            You may need to have something selected before opening the Shortcuts preferences dialog.
              @mitcorb said:
              Question:
              Select two or more entities.
              If the menu is not visible in the SU UI the shortcut list won't display it.
