    Getting normal to cylinder face
    5 Posts 3 Posters 991 Views 3 Watching
    • P Offline
      peterjohnson84
      Hi there,
      I am having some trouble with some code I'm writing and was wondering if there was a simple solution that I'm unaware of.
      My aim is to find vector the normal to a cylinder face (where the cylinder has beeen 'stored' as a group) and from that, work out the orientation of the cylinder group. So far, I have been able to do this for a cylinder which I created. However if I rotate the cylinder and perform the same operation, the normal vector does not change with the rotation i.e. if I create a cylinder aligned along the z axis - circle.normal will always give (0,0,1) despite any rotation i perform on the group.
      I assume the information about the rotation is stored somewhere and from this I could work out the cylinder orientation - but I'm at a loss to work out how to do this.
      Any help with this would be greatly appreciated.
        Try adjusted_normal=face.normal.transform!(group.transformation)
        where 'group' is the container of the circle-'face' on the end?
        • P Offline
          peterjohnson84
          Cheers TIG, that did the trick.
            bentleykfrog
            Just answered my own question, transformation is relative to the parent.
            Here's some more compact code:
            normal = entity.normal
            for i in (0..(path_to_entity.length-2)) do
              e = intersect_path[i]
              normal = normal.transform! (e.transformation)
              bentleykfrog
              Sorry for digging up an old topic, but will this work with nested groups/component instances?
              i = 0
              path_to_entity.each {|entity|
                i +=1
                break if i >= path_to_entity.length
                normal = normal.transform! (entity.transformation)
              Or does transform represent a transformation from the models axes? (ie, just require normal = normal.transform! (entity.transformation)
              Just for background, I'm trying to get a model based vector of the face normal as in peterjohnson84's example
