    How to convert language for plugin
    13 Posts 5 Posters 1.7k Views 5 Watching
      rongvuong
      how to convert language for plugin as file fur_lang.txt by plugin Make Fur
      thank so much
      • Didier BurD Offline
        Didier Bur
        Browse the zip archive and you'll see some files like 'fur_lang_xx.txt' where xx stands for the country.
        Below is the french translation file.
        Type|Type
        Density|Densité
        MaxNumber|Nombre max
        Length|Longueur
        RootWidth|Largeur base
        Stiffness|Raideur
        TopJitter|Amplitude hauteur
        WidthJitter|Amplitude largeur
        StiffnessJitter|Amplitude raideur
        Divide|Divisions
        Valid Distance|Distance valide
        direction|Direction
        force|Force
        Make by Component|Générer un composant
        Units|Unités
        PRESET?|Sélectionner un réglage
        Open such a file in your text editor, and translate the right part of each line, leave the left one unchanged.
        Don't forget to post your language file when done !
        That's it.
        DB
          rongvuong
          thank you very much
          but I want to use for many other plugins ?
            How to translate plugins depends on the plugin - there is no unified system. You need to check with each plugin/author.
              @rongvuong said:
              thank you very much
              For many of my plugins there are .lingvo files that hold the translations for a companion script deBabelizer.rb
              E.g. 2DtoolsEN-US.lingvo - the US-English version in the 2Dtools sub-folder
              has a Spanish version 2DtoolsES.lingvo
              If a file matching the PC's locale is found that is used in preference to the default.
              The translations are one per line, in the lingvo format it's...
              The cat<==>El gato
              etc
              Where one of my plugins supports 'deBabelizing' there are often several lingvo files supplied or added to by users from other locales...
              What is your 'locale' ?
              • K Offline
                ktslambieng
                how to change languages into ExtrudeTools plugin to Vietnamese
                how can i edit it?!?!?
                  Is there a SUp 'locale' version for 'Vietnam'?
                  Type this in the Ruby Console
                  Sketchup.get_locale
                  'VI' is the locale for Vietnam.
                  If you get this then make a copy of the 'lingvo' file you want to translate [in the ../Plugins/TIGtools/ folder], e.g.
                  extrudeEdgesByRailsEN-US.lingvo
                  as
                  extrudeEdgesByRailsVI.lingvo
                  NOTE: IF your PC is actually set to the default EN-US locale you can still 'trick it' into displaying a Vietnamese translation by editing that 'lingvo' file [or by making an alternative lingvo to suit your actual locale, e.g. FR ??].
                  Here we'll assume EN-US... i.e. extrudeEdgesByRailsEN-US.lingvo is to have your Vietnamese translations added to it [I suggest you make a backup copy of the original file in case you mess up].
                  To edit the 'lingvo' file you need to open it in a plain-text editor like 'Notepad.exe' - do NOT use a word-processor.
                  It is a simple text file and is easily changed.
                  Each line of text represents a word or phrase used in the tool, with its translation; thus:
                  Extrude Edges by Rails<==>Extrude Edges by Rails
                  The default version has the same text each side of the 'separator' <==>
                  So you would choose an appropriate translation for "Extrude Edges by Rails" and add that to the right-hand side of the <==> - for example:
                  Extrude Edges by Rails<==>để extrude cạnh dọc theo đường ray
                  or
                  Extrude Edges By Rails: Select the 'Profile' Curve...<==>để extrude cạnh dọc theo đường ray: chọn một đường cong để sử dụng cho phun ra các...
                  [My Vietnamese is NOT very good! As you can see!!]
                  Remember you might need to adjust your translation to make the text fit into the available space.
                  Repeat this for all lines until you have a suitable translation of that tool's instructions etc.
                  Save the 'lingvo' file.
                  Re-run the tool to see the changes to the text...
                  You will need to do this for each 'extrude.. .lingvo' file in the ../Plugins/TIGtools/ folder that you wish to translate...
                  When you have your set, then post them here for others to use too... 😉
                  • K Offline
                    ktslambieng
                    ola la..thank you very much... 😍 😍
                    I will try to translate it into Vietnamese, and i will port when done
                    so.again... thank you very much
                      rongvuong
                      thank you
                      please you can write a tut Photos ? ^^
                      I can not do it
                        @rongvuong said:
                        thank you
                        I can not do it
                        Can you try the steps in the notes I gave and tell me at which step you cannot continue...
                        For example - can you get your 'locale'?
                        Can you find the '.lingvo' files etc ?
                        • K Offline
                          ktslambieng
                          I finished change languages into ExtrudeTools plugin to Vietnamese
                          can u download in
                          http://www.mediafire.com/?5a1hbft2v356gxq
                          thank TIG verry much
                            can u download in
                            Well done. 😄
                            If other Vietnamese users want these files, then I suggest they download the compressed file and extract them into the TIGtools subfolder in the ../Plugins/ folder. Make a new folder to move the equivalent original files [i.e. extrude...EN-US.lingvo] into first in case you mess up or want to revert to the English versions later...
                            'ktslambieng' - note that you can attach files [compressed like this] directly to your post...
                            I have done so for you here... extrudeEdgesTools-VietnameseLingvos.rar
                            You can always contact 'ktslambieng' by PM for guidance...
                              rongvuong
                              thank you very much
                              I understood and did it
                              but with the file don't have "locale"?
