    How can I slice a solid (like CAD) ?
    12 Posts 5 Posters 1.5k Views 5 Watching
      anonmyous
      Is there any ruby to slice a solid by 3 points (like CAD) ?
      Help me pls.
        you have better: by 2 Points πŸ˜‰
        Zorro 2 by Whaat
          anonmyous
          oh, anyone can modify or rebuild this to slice by 3 point ?
          thank you.
          • mitcorbM Offline
            mitcorb
            Although this may not apply to your question exactly, I often use a circle drawn large enough to extend beyond what I wish to cut, make a group of it, move it into place on the cutting plane, intersect with selected and perhaps erase away what I do not want or [group it/copy move it] a specific distance and then reposition after cleanup.
            I would do, and have done this also in CAD. Specifically Autocad.
            You can also use a circle or any planar figure as a reference plane with say a line segment drawn on its surface as a directional guide for your cursor to move selected geometry (faces or edges) carefully in a crowded model.
              Sorry have you an example of a slice a solid wanted? (image)
              It's just a face or it's a volume or...?
                anonmyous
                yeah I just want to slice a solid in 2 parts with a 3-points defined.
                  If you connect those 3 points, a face will be created which can be used to intersect with the solid. See screenshots attached.
                    Tricky but you have the same with Zorro2 πŸ˜‰
                    Orient your objet in the 3D space or use View top face etc (more easy) ...
                    Just 2 points for the line cutting
                    One line for close the open face
                    Erase the line
                    (Click image if scrollbar)
                      anonmyous
                      many thanks for all
                      but I also want to keep both of them and it's wonder if someone write a ruby for it πŸ‘
                      • jeff hammondJ Offline
                        jeff hammond
                        you might want to try using a WorkPlane..
                        http://forums.sketchucation.com/viewtopic.php?t=31204
                        use three points to draw it then intersect..
                        right click>work plane>delete ...to get rid of it after intersecting.
                        dotdotdot
                          or just after Zorro2 just Copy move one, kill the start one
                          and close the 2 objects πŸ˜‰
                          It's not a big deal : just 2 lines πŸ˜‰
                          With the Work plane, you must also draw 2 lines
                          for close the objects πŸ˜‰
                          PS There is a function "Cap Holes" πŸ˜‰
                          So just Copy move one object
                          Select all then Right Click/Cap Holes
                          I belive that is inside Sketchy Bevels by CPhillips πŸ˜‰
                          That works fine β˜€
                          Another work around
                          Zorro2
                          Group one object
                          Move it
                          Explode
                          Select all
                          Caps hole β˜€
                          et voilΓ  πŸ˜„
                            anonmyous
                            yeah WorkPlane seem to be good in this case, it helps me make a fast plane.
                            you're so enthusiasm, thanks all
