    How can I slice a solid (like CAD) ?
    12 Posts 5 Posters 1.6k Views 5 Watching
      you have better: by 2 Points πŸ˜‰
      Zorro 2 by Whaat
        anonmyous
        oh, anyone can modify or rebuild this to slice by 3 point ?
        thank you.
        • mitcorbM
          mitcorb
          Although this may not apply to your question exactly, I often use a circle drawn large enough to extend beyond what I wish to cut, make a group of it, move it into place on the cutting plane, intersect with selected and perhaps erase away what I do not want or [group it/copy move it] a specific distance and then reposition after cleanup.
          I would do, and have done this also in CAD. Specifically Autocad.
          You can also use a circle or any planar figure as a reference plane with say a line segment drawn on its surface as a directional guide for your cursor to move selected geometry (faces or edges) carefully in a crowded model.
            Sorry have you an example of a slice a solid wanted? (image)
            It's just a face or it's a volume or...?
              anonmyous
              yeah I just want to slice a solid in 2 parts with a 3-points defined.
              • GaieusG
                If you connect those 3 points, a face will be created which can be used to intersect with the solid. See screenshots attached.
                  Tricky but you have the same with Zorro2 πŸ˜‰
                  Orient your objet in the 3D space or use View top face etc (more easy) ...
                  Just 2 points for the line cutting
                  One line for close the open face
                  Erase the line
                  (Click image if scrollbar)
                    anonmyous
                    many thanks for all
                    but I also want to keep both of them and it's wonder if someone write a ruby for it πŸ‘
                    • jeff hammondJ
                      you might want to try using a WorkPlane..
                      http://forums.sketchucation.com/viewtopic.php?t=31204
                      use three points to draw it then intersect..
                      right click>work plane>delete ...to get rid of it after intersecting.
                        or just after Zorro2 just Copy move one, kill the start one
                        and close the 2 objects πŸ˜‰
                        It's not a big deal : just 2 lines πŸ˜‰
                        With the Work plane, you must also draw 2 lines
                        for close the objects πŸ˜‰
                        PS There is a function "Cap Holes" πŸ˜‰
                        So just Copy move one object
                        Select all then Right Click/Cap Holes
                        I belive that is inside Sketchy Bevels by CPhillips πŸ˜‰
                        That works fine β˜€
                        Another work around
                        Zorro2
                        Group one object
                        Move it
                        Explode
                        Select all
                        Caps hole β˜€
                        et voilΓ  πŸ˜„
                          anonmyous
                          yeah WorkPlane seem to be good in this case, it helps me make a fast plane.
                          you're so enthusiasm, thanks all
