    Reset color to average texture color
    5 Posts 3 Posters 424 Views 3 Watching
    • Al HartA Offline
      Al Hart
      Sometimes we create a new material from a texture and want to set the material color to the average texture color.
      We use to do this by setting the material color to nil.
      new_matl.color = nil	# use average texture color
      But this stopped working.
      However, we found a fix where if you set to color to itself after setting it to nil, it works ok again:
      new_matl.color = new_matl.color # this causes new color to be used properly
      Go figure???
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
        Why didn't you use
        new_matl.color = new_matl.texture.average_color if new_matl.texture
        in the first instance ?
        šŸ˜•
          When?
          • Al HartA Offline
            Al Hart
            Thanks,
            Just the kind of advice I need. I'll go try it out.
            ... Seems to work great!
            Al Hart
            • Al HartA Offline
              Al Hart
              @thomthom said:
              When?
              I don't know when it stopped working - sometime after I discovered that setting the color to nil did work (several years ago), and this past month when people started reporting bugs. (So of course, I suspected SU 8. But I just tried SU 7 and it fails there as well. So who knows...)
              The bug was interesting, because the color looked OK in the SketchUp model until you saved and reloaded the model. However, the material editor showed that the material color was not set. When you click reset color it sets the color properly.
              Al Hart
