    Sattelite image on sketchup
    6 Posts 4 Posters 561 Views 4 Watching
      Tinux
      Hi !
      I need for a project to use in background an high def sattelite image. So i use many snapshots with the tool
      included in sketchup ('add a place'). However it creates on each image in the bottom a logo and some text "condition of use / privacy etc..".
      It's really a problem because as i want to make an animation, then all my scene sparks...
      Is there a solution to desactivate that logo and text ? Am i oblige to do my own sattelite image using a photomerge tool or
      something like that.. ? What is the better to do ?
      Thanx a lot !
      • mitcorbM Offline
        mitcorb
        You are getting these snapshots from Google Earth?
        The source is requesting that you acknowledge conditions for use? Or is this a watermark, and therefore, it is copyrighted material requiring you to obtain permission to use?
        Unless I am misunderstanding, which is very likely, you may need to pay a fee for use of copyrighted material.
        • jeff hammondJ Offline
          jeff hammond
          he's talking about 'add location' in su8.
          the image comes in with google's logo as well as a copyright notice on it.
          as far as i know, the only way to get rid of it is to import a larger image than necessary then delete the bottom part..
          dotdotdot
            or make some overlappings 💭
            So big scale possible! 😎
            By Kabak, so you just keep one copyright 😉
            http://www.pixenli.com/images/mini/1289482216092670100.jpg
            http://www.pixenli.com/images/mini/1289482240055168100.jpg
              Tinux
              Thanx Pilou !
              However there is a problem when you use more than 2 pictures in y axis cause images are between Layer 0 (that you can't delete) and an other one (Google earth snapshot) so when you want to explode "line by line" it fucks because of non-visible layer..
              I may do that badly... or just do it step by step.. ?
                Tinux
                Ok i found the solution : the first images have to be on the top of the final hi-res image and then pick up the captures by going to the bottom..
                Then no problem
