    Plugin push/pull
    6 Posts 4 Posters 771 Views 4 Watching
      dannyver
      is ther a plugin that can push/pull insite a group/component whit open it?
        If you edit right click/ Edit Group/component you can make any PushPull you want 😄
        Or any boolean opération you want etc...
        Maybe a little image will be more explicit of what do you want 😄
          Did you mean. "... a plugin to pushpull a face inside a group/component without opening the group/component to edit it" ?
          If so I think not - but it would be possible to write a tool to do that...
            dannyver
            yes that is what mean, can you write that, that would be great!!
              A4chitect has this http://forums.sketchucation.com/viewtopic.php?t=17040
              I haven't tried it though as I don't see the need. Let us know if it's any good?
                dannyver
                this scales the group no puss/pull or are i doing somthing wrong ❓
