    Save selected plugin?
    7 Posts 5 Posters 3.1k Views 5 Watching
    • J
      j_forrester
      Hi guys,
      Just wondered if there is a "save selected" plugin about? I used to work on a mac where you could have multiple sketchup files open and copy and paste in place. It seems on a PC this is not possible?
      I have a large model with many buildings which I want to work on individually in serate scenes to speed things up.
      Any help would be much appreciated.
      Jaimie
      • thomthomT
        Under Windows you can Copy and Paste in Place between windows.
        You mean right clicking a component and then Save Component ?
        • J
          j_forrester
          thanks thom,
          I thought opening another session it would not reconise what it was copying. Also save component way as you suggest works well, I thought there may have been a option to save selected but saving as a component first is hardly going out your way.
          Many thanks.
          • jeff hammondJ
            jeff hammond
            @j_forrester said:
            thanks thom,
            i'm on mac but i don't think it matters for this..
            copying goes to the clipboard so it's stored there, not within sketchup..
            for instance, i can copy an object and quit sketchup.. relaunch sketchup then paste it.. (and weird as it may sound, i have done this in that past ๐Ÿ˜„ )
            dotdotdot
            • TIGT
              I think [?] I wrote a 'save selected tool' once...
              [Also a 'similar save layer'...]
              It simply erased everything that wasn't selected [and not needed]... and did an export as a 'skp'... and then 'undid' the erase back to where it had been [luckily an 'export' is not undoable]...
              I can't be bothered to find it/them now... but it's/they're around here somewhere... ๐Ÿ˜Ž
              • mitcorbM
                mitcorb
                If you were old as the Sphinx, I could understand your forgetting what you have done, but your statement scares me ๐Ÿ˜ฒ
                • TIGT
                  If I [or you for that matter!!] could have been arsed to do a simple search on this forum you'd have got this 'export by selection' = http://forums.sketchucation.com/viewtopic.php?p=183756#p183756
                  OR this one that does it by 'export by layer' = http://forums.sketchucation.com/viewtopic.php?p=183609#p183609
                  ๐Ÿค“ ๐Ÿ˜’
