    [req] tracing bitmaps?
    39 Posts 9 Posters 6.3k Views 9 Watching
    • charly2008C Offline
      charly2008
      Hi 3eighty,
      I have Inkscape for a while, but I have not worked much with it. But it seems to also not bad and it is free. The problem in both programs the result depends on the quality of the bitmap.
      Charly
        museummaker
        Bookmarked 👍 +1
          charly2008
          Hi to Everyone,
          I have drawn a simple rectangle in SketchUp and this exported as BMP. With this BMP I experimented in both programs. From Vector Magic I received a double rectangle instead a single rectangle and from Inkscape I received a very different result. While the image edges are represented as single line or vectors.
          I have less experience in vectorization of objects and I do not know if I'm doing something wrong. Are here in the forum experts who are familiar with this procedures? I would be very happy if someone could help and explain.
          Charly
          • jo-keJ Offline
            jo-ke
            OK here is my rug-problem! It's a different situation but the same problem:
            I am drawing the designs of my rugs with photoshop or coreldraw. If the design is a bitmap I can trace it with coreldraw and I can save it as a dwg file. unfortunately the vectors are not filled when I import it to SU so I can't use the pushpull function
            coreldraw:
            SU after import
            real rug
            http://www.doerr-lu.de/nmweb//_actions/nmweb_action_getfile.php?field_fileid=537
            trace.skp
            http://www.zz7.de
            • jo-keJ Offline
              jo-ke
              I used the same method with the floorplan
              vectorising in corel X3. it was a quite good result, the tracing function in corel is very good. no postprocess, export as dwg, import in SU and no filled fields...
              grundriss-trace.skp
              http://www.zz7.de
                charly2008
                Hi jo-ke,
                there are many stray lines (plugin) . they have to be corrected manually.
                Charly
                trace.skp
                • jo-keJ Offline
                  jo-ke
                  wow charly, this looks better. how did you fill the fileds?
                  http://www.zz7.de
                    charly2008
                    it is the same in this drawing stray lines and open contours.
                      charly2008
                      With the plugin "make faces 1.4"
                        @charly2008 said:
                        I removed all the stray lines but you can see some of the contour lines are not closed. This finding is hard work.
                        And surely that isn't usable as a working model, is it? There isn't a single straight line there...
                          charly2008
                          I removed all the stray lines but you can see some of the contour lines are not closed. This finding is hard work. Oh I remembered there is a trouble shooting style.
                          • jo-keJ Offline
                            jo-ke
                            I can't find the make faces plugin...
                            at the moment I'm trying the plan tools http://forums.sketchucation.com/viewtopic.php?f=323&t=30512&start=0&hilit=make+faces
                            http://www.zz7.de
                              charly2008
                              Hi Thomas,
                              [/quote]
                              And surely that isn't usable as a working model, is it? There isn't a single straight line there...[/quote]
                              that seems to be the Problem!
                              Charly
                                charly2008
                                Jo-ke,
                                if it is not in your Tools menu, have a look here:
                                File Not Found
                                (www.smustard.com)
                                • jo-keJ Offline
                                  jo-ke
                                  @charly2008 said:
                                  Jo-ke,
                                  File Not Found
                                  (www.smustard.com)
                                  Ah thank you. now of course I've found it.
                                  http://www.zz7.de
                                    charly2008
                                    Thomas,
                                    I have found now a plan with a resolution of 3335 x 4151 pixels. The result is good. But what I still do not understand is that double lines are generated.
                                    Loft.skp
                                      Ah, it create a line for each side of the black pixels... is there a setting for that in the app you use?
                                        charly2008
                                        Thomas,
                                        In Inkscape I did it. The error was to use the edge detection. You have to use Brightness cutoff. Well, at least most of the lines are individual lines. Please have a look into the attached file.
                                        Charly
                                        Loft.skp
                                        • jo-keJ Offline
                                          jo-ke
                                          The result is perfect!
                                          I've quickly used "make faces" 😉 and pushpull and the result looks like that:
                                          (of course many lines (doors, fonts,...) need to be corrected but that is easy with that result.)
                                          http://www.zz7.de
                                          • 2 / 2
