    [req] tracing bitmaps?
    39 Posts 9 Posters 6.3k Views 9 Watching
    • jo-keJ Offline
      jo-ke
      I used the same method with the floorplan
      vectorising in corel X3. it was a quite good result, the tracing function in corel is very good. no postprocess, export as dwg, import in SU and no filled fields...
      grundriss-trace.skp
      http://www.zz7.de
      • charly2008C Offline
        charly2008
        Hi jo-ke,
        there are many stray lines (plugin) . they have to be corrected manually.
        Charly
        trace.skp
        • jo-keJ Offline
          jo-ke
          wow charly, this looks better. how did you fill the fileds?
          http://www.zz7.de
            charly2008
            it is the same in this drawing stray lines and open contours.
              charly2008
              With the plugin "make faces 1.4"
                @charly2008 said:
                I removed all the stray lines but you can see some of the contour lines are not closed. This finding is hard work.
                And surely that isn't usable as a working model, is it? There isn't a single straight line there...
                  charly2008
                  I removed all the stray lines but you can see some of the contour lines are not closed. This finding is hard work. Oh I remembered there is a trouble shooting style.
                  • jo-keJ Offline
                    jo-ke
                    I can't find the make faces plugin...
                    at the moment I'm trying the plan tools http://forums.sketchucation.com/viewtopic.php?f=323&t=30512&start=0&hilit=make+faces
                    http://www.zz7.de
                      charly2008
                      Hi Thomas,
                      [/quote]
                      And surely that isn't usable as a working model, is it? There isn't a single straight line there...[/quote]
                      that seems to be the Problem!
                      Charly
                        charly2008
                        Jo-ke,
                        if it is not in your Tools menu, have a look here:
                        File Not Found
                        (www.smustard.com)
                        • jo-keJ Offline
                          jo-ke
                          @charly2008 said:
                          Jo-ke,
                          File Not Found
                          (www.smustard.com)
                          Ah thank you. now of course I've found it.
                          http://www.zz7.de
                            charly2008
                            Thomas,
                            I have found now a plan with a resolution of 3335 x 4151 pixels. The result is good. But what I still do not understand is that double lines are generated.
                            Loft.skp
                              Ah, it create a line for each side of the black pixels... is there a setting for that in the app you use?
                                charly2008
                                Thomas,
                                In Inkscape I did it. The error was to use the edge detection. You have to use Brightness cutoff. Well, at least most of the lines are individual lines. Please have a look into the attached file.
                                Charly
                                Loft.skp
                                • jo-keJ Offline
                                  jo-ke
                                  The result is perfect!
                                  I've quickly used "make faces" 😉 and pushpull and the result looks like that:
                                  (of course many lines (doors, fonts,...) need to be corrected but that is easy with that result.)
                                  http://www.zz7.de
                                  • 2 / 2
