    [req] tracing bitmaps?
    39 Posts 9 Posters 6.4k Views 9 Watching
    • jo-keJ
      jo-ke
      Is there any plugin to trace bitmaps of constructionplans to get polys?
      http://www.zz7.de
      • thomthomT
        No. You need to find some specialised image processing application for that - converting bitmaps to vector. But beware that they rarely end up very good or accurate.
        Illustrator has a tracing function - but I don't think it do lines - it do filled shapes. And is more oriented to tracing hand drawings instead of plans.
        • charly2008C
          charly2008
          the best Application I've found so far is Vector Magic. It provides very good results.
          http://vectormagic.com/home
          Charly
          Sketchup DXF
          Vector Magic
          Justitia.skp
          DXF File
          • thomthomT
            How does it work with plans?
            The problem with tracing plans is that lines should should be perfectly straight and parallel often slightly off. And that in turns makes for problems if you try to model from or continue drawing to after vectorizing them.
            • mitcorbM
              mitcorb
              Nice find, Charly:
              Also, seems a reasonable value.
              • charly2008C
                charly2008
                Hi Thomas,
                I do not have good plans available. The example below is from a low resolution JPG.
                Charly
                Grundriss.skp
                • thomthomT
                  If you turn on edge colour by axis?
                  • charly2008C
                    charly2008
                    You think so?
                    Lines by colors.skp
                    • thomthomT
                      Not bad... I get DWGs from AutoCAD worse than that...
                      • jo-keJ
                        jo-ke
                        Oh thank you for your help.
                        I've attached a typical florplan, that I usually use.
                        I can trace that with corel trace, export it as a dwg, import it to sketchup, but the result isn't as good as I need to have.
                        charly, I will check your link, sounds usefull.
                        http://www.zz7.de
                        • thomthomT
                          hmmm... the lines there aren't even. the fold distorted them.
                          Would be interesting to see the results you get.
                          Though I think I'd personally trace that by hand in order to ensure clean geometry.
                          • jeff hammondJ
                            jeff hammond
                            wow, that's pretty sloppy (as far as precision is concerned)
                            i'm thinking the best approach for that file is manually tracing /redrawing in sketchup or another type of cad app.
                            dotdotdot
                            • FrederikF
                              Frederik
                              i'm thinking the best approach for that file is manually tracing in sketchup.
                              I agree...
                              Whenever I've got drawings/plans like this, I import them to SU, scale accordingly and trace it in SU...
                              I don't believe you'll experience any shortcut in this case...
                              Cheers
                              Kim Frederik
                              • jo-keJ
                                jo-ke
                                You're right, the quality of the plan is terrible. But this is often the quality I get from the customers.
                                Tracing it by hand in sketchup is normaly the way I'm doing it. I thought that there may be a special tracing plugin to do that job.
                                Another usefull part for me of this funktion would be designing rugs. I usually do that in corel draw, then I export that as a bitmap and texture a poly in SU. In that case I'm not able to change single colors of the pattern. If I export the bitmap to su as a dwg, the result isn't usable. In the next days I'm going to upload some examples.
                                http://www.zz7.de
                                • kenK
                                  ken
                                  So I am reading these post, go back to my email and find this program notice. Note, I haven't tried this program, however, I do have their PDF 2 DXF program and it works OK.
                                  So I am not endorsing this program, but just showing another possible solution.
                                  http://www.cadkas.com/downengcad2.php
                                  Ken
                                  • charly2008C
                                    charly2008
                                    I've tried different options with the plan. This was the best thing I could achieve so far. A professional may be able to get even more.
                                    Charly
                                    Grundriss.skp
                                    • charly2008C
                                      charly2008
                                      After I had optimized a bit the image in PS , the plan now looks like this. I do not know whether this is helpful.
                                      Charly
                                      Grundriss.skp
                                      • jo-keJ
                                        jo-ke
                                        the first one looks quite good. I don't have SU8 yet, so I'm not able to open the file.
                                        I think the problem will be after the push/pull function, the walls won't look plane.
                                        But this could be a solution for my carpet problem
                                        http://www.zz7.de
                                          3eighty
                                          Inkscape.org .....Check out this great FREE program...Does what you want and lots more....
                                          • mitcorbM
                                            mitcorb
                                            I thought there were size limitations in Inkscape, ie pixels/ resolution? Has this improved? I will check if I can.
                                            • 1 / 2
