    Cannot import .3DS or .DWG or .DXF (Pro)
    3 Posts 2 Posters 484 Views 2 Watching
    • N Offline
      Nstocks
      I'm trying to import a 3D model into Sketchup from ArchiCAD. I've exported it as a .3ds, .DWG and .DXF but none of the file will open.
      When I click import in Sketchup, the files I want to import are greyed out which means they cannot be opened, even though Google say these files are supported.
      I'm using Sketchup Pro 8, ArchiCAD 14 and MAc OS X 10.6.4. I also have AutoCAD for MAc if that helps.
      Am I missing something here?
      Thank You
      • jeff hammondJ Offline
        jeff hammond
        make sure to select the format you're trying to import.. once you select the proper file type, those files will no longer be greyed out.
        screenshot from mac sketchup import dialog.
        dotdotdot
        • N Offline
          Nstocks
          Perfect thank you!
          I've not used sketchup for a while... ArchiCAD is making too much hard work for the early design stage for me though..
          Thank You
