    Place component copies along curve?
    8 Posts 5 Posters 747 Views 5 Watching
      JohanR
      😕 Is there any easy way to do this? 😕
        You have some but...
        The more funny and versatile is "Component Stringer" by Chris Fullmer
        The only difficulty is the curious first position of the component!
        (90° vertical against the position wanted 😒
        But as you can edit the component and axis of the component, that is not a real difficulty 😉
        Position between them is given by segments of the curve itself!
        (so work on it the divisions before launch the plug)
        Take "None" for your first tests before explore variations ☀
        One of the more funny and powerful plug! 😎
        • Chris FullmerC Offline
          "Stringer in the night" - I like it Frenchy.
          There is also the plugin pathcopy by Rick Wilson. It is really good too:
          (www.smustard.com)
          All my Plugins I've written
            JohanR
            Thanks guys, these are some great plugins. I´ve tried some, but the still remaining problem is that i can´t control the distance between and copy as many components as i want along the curve ;/ I guess i have some manually work ahead of me.
            • BoxB Offline
              If you divide the curve into the number and spacing you want then the components go to those points.
                With PathCopy which Chris linked you can specify the distance between components.
                  JohanR
                  Holy smoke! That´s awesome Thom. Well i did everything manually this time, but, there will be other times this will come very handy.
                    And for the "Component Stringer" by Chris I have written 😉
                    Fredo 6 Bezier Splines I believe has a Divider, Segmentor curves...
