    SU (and plugin etc) installation folders
    5 Posts 4 Posters 377 Views 4 Watching
      Hi all, I need some help (for help).
      I use XP and the default installation folder for SU is here:
      C:\Program Files\Google\Google SketchUp #
      Could you add where this folder should be on Vista, Win 7 (both 32 and 64 os's) should be? And on these os's are the plugins etc. folders just there, under the ain SU folder or elsewhere somehow?
      Also, I forget where plugins, components, materials and styles are stored on the mac (I know that's completely different)
      Thans in advance.
        JuanV.Soler
        Hi Gai, under Vista 32 is the same C:\Program Files\Google\Google SketchUp #
        and folders :
          Vista default Sketchup 32bit installation is in
          C:\Program Files\Google\Google SketchUp #\
          [The '#'==Version number e.g. '8']
          The Plugins folder etc are always located directly inside that...
          I'm 99.9% sure the Win7 installation is the same...
          I suspect that on a 64bit PC the path changes for non-64bit programs to be
          C:\Program Files (x86)\Google\Google SketchUp #\
          The typical MAC installation is in
          Macintosh HD/Library/Application Support/Google SketchUp #/SketchUp
          To find where Sketchup is actually installed on your PC or MAC type/copy+paste this snippet into the Ruby Console
          Sketchup.find_support_file("")
          which returns the path to the Sketchup folder for that version/OS. 🤓
            I can confirm that TIG's 0.01% doubt is in fact the correct path and his suspicion of the location in WIN7 64bit is also correct.
              okay, thanks guys a lot. I keep bouncing into users that never know where and how their stuff is installed and it's sometimes hard to help when one needs to stab in the dark.
