    [Plugin] Editing: Hide Context - v1.1 20101019
    14 Posts 8 Posters 10.8k Views 8 Watching
    • TIGT
      (c) TIG 2010
      Permission to use, copy, modify, and distribute this software for
      any purpose and without fee is hereby granted, provided the above
      copyright notice appear in all copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Script:
      ##hideEverythingElse.rb
      place it in the ../Plugins/ folder...
      Usage:
      This script adds a new function to the 'View' menu.
      'Editing: Hide Context'
      It 'toggles'.
      If it is active it is shown 'ticked'.
      If it is inactive it is shown 'unticked'.
      The default setting is 'inactive'.
      The last setting is remembered with the saved model across sessions.
      When it is 'active' if you edit a component-instance or a group then
      everything else in its context is hidden from view: unlike the built-in
      'View'>'Component Edit'>'Hide Rest of Model' and
      'View'>'Component Edit'>'Hide Similar Instances',
      which will either show OR hide EVERYTHING both inside AND outside of the
      editing context.
      'Editing: Hide Context' is limited to hiding only objects in the edited
      instance's context.
      This may be more useful than 'Hide Rest of Model' if there is something
      outside of the context that you still want to see [e.g. to snap to], but
      you do want objects in the immediate context to be hidden temporarily as
      they obscure your view...
      Remember to set 'View'>'Hidden Geometry' to 'off' for an unobstructed view.
      Note that because it is a menu-item you can shortcut-key to it.
      Donations:
      by PayPal to info @ revitrev.org PayPalButton ___________________________________________________________________________
      Version:
      1.0 20101019 First Release.
      1.1 20101020 Recast as 'Editing: Hide Context',hides editing context ONLY.
      ___________________________________________________________________________##hideEverythingElse.rb
        Hide Everything Else except selected ?
        • EarthMoverE
          EarthMover
          Very Nice. An "isolation mode" plugin. πŸ‘
          Content Creator at Skapeup
          • D
            DIEGO-RODRIGUEZ
            thanks tig.
            I do not understand,
            This plugin is like having clicked options:
            • Hide the rest of the model.
            • Hide similar components.
              no?
            not hide groups/compontes that are within group/componte active
            • P
              Panga
              Hi all,
              Thanks TIG for this plugin ! Seeing it something came to my mind. Could it be possible that the isolated selection goes to the origin during the time of editing ? Then it comes back to his place when editing's over ? could that be a way to avoid the clipping issue in big models ? Just and idea..
              Regards.
              • TIGT
                To clarify...
                It works like 'View' >'Component Edit' >'Hide Rest of Model' and >'Hide Similar Instances' [in fact it uses those] BUT what it ALSO does is hide everything else during an editing session including other instances and geometry - something that the built-in tools don't.
                So for example make several groups and group some of them, nest some of them.
                Edit one and other objects might be in your way.
                Toggle the 'View' >'Component Edit' to 'hide' the rest etc and now some objects will be temporarily hidden and your view will improve... but there might still be some nested objects obscuring your view.
                Activate 'View' >'Editing: Hide Everything Else' and even those objects will be temporarily hidden. πŸ€“
                • TIGT
                  @diego-rodriguez said:
                  thanks tig.
                  Not hide groups/components that are within group/component active
                  I see the point - I will work on an alternative that is like 'View >'Component Edit' >'Hide Rest of Model' but ONLY hides what is in the current entities set... To hide everything you'd still use 'View >'Component Edit'... πŸ˜’
                  • TIGT
                    Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=280618#p280618
                    which I think addresses the issues raised.
                    Please read the notes on the linked page.
                    The toggle now hides everything in the editing context only... πŸ€“
                    • J
                      JuanV.Soler
                      Thanks TIG, I am testing it.
                      Mind you are quick πŸ˜„
                      cheers
                      • C
                        caleidos4d
                        Thanks TIG!!! πŸ‘
                        http://www.caleidos4d.it
                        • D
                          DIEGO-RODRIGUEZ
                          thanks tig. very fast response.
                          I tried l plugin, but I can not understand how it works.
                          maybe my English is very bad and I did not explain well.
                          attached image and file the idea I have.
                          http://img89.imageshack.us/img89/5195/hidek.gif
                          hide.skp
                          • TIGT
                            Got you!
                            That's another tool 'Editing: Show Geometry Only'...
                            • TIGT
                              Here is 'Editing: Show Geometry Only' http://forums.sketchucation.com/viewtopic.php?p=280810#p280810
                              • T
                                TraxXx
                                Hello TIG,
                                Thought this plugin would serve for 2D exports but it's actually not. I might be wrong but I don't believe there is a plugin that hides the rest of the model from the 2D export. For instance, sometimes, I'd like to just make a 2D export of a furniture inside a whole project in order to show how it looks on its own. Even though the "Hide rest of the model" function is enabled, it's ignored in the export file (png or jpeg). No matter how much of the model was visible in the viewport, the whole model will be seen in any cases. The only workaround for me right now is just to select all, unselect the only element that I want to make visible and delete rest of the model, do the export, and undo the objects removal. But it can get tricky when there are groups of groups and you need to manage inside them which you want to keep or not...
                                Do you think you could create a feature that would somehow allow this ?
                                Thank you πŸ˜„
