    [Questions Plugins] Hide Groups / inactive components
    16 Posts 5 Posters 1.3k Views 5 Watching
      DIEGO-RODRIGUEZ
      hello.
      There is some plugin that allows hide groups / inactive ingredients that is within the group / active component where I am working?
      • TIGT Online
        It's built in - choose one or both of these optionsHideRest.png It's a 'toggle' on/off...
        It shows my own shortcuts...
          DIEGO-RODRIGUEZ
          if tig, use this option much.
          but I meant to hide groups / components are inside the group / active component in which I work.
          the option you mentioned, it hides the remainder of model that is outside the group or active componet I'm working on
          • TIGT Online
            But I meant to hide groups / components are inside the group / active component in which I work.
            The option you mentioned, it hides the remainder of model that is outside the group or active component I'm working on
            Understood!
            You need a hide_everything else tool.
            There are already some tools to invert the selection and then hide selected...
            You then do you edit and on completion unhide the rest ?
            πŸ˜•
              DIEGO-RODRIGUEZ
              http://img299.imageshack.us/img299/7641/hidez.jpg
              • Chris FullmerC Offline
                This is also David_H's #1 feature request, if that matters...... πŸ‘Š πŸ˜†
                All my Plugins I've written
                • TIGT Online
                  I have a half-baked version that should work if the InstanceObserver wasn't [currently] broken in v8 [was OK in v6!]...
                  We await an update to the Observers...
                    What's broken?
                    I had problems in earlier versions...
                    • TIGT Online
                      The onOpen() and onClose() methods don't trigger for me in v8 - try the API example.
                        They do for me - I had problems in earlier versions - at least SU7.x.
                        http://www.thomthom.net/software/sketchup/observers/
                        I do now see I noted that in SU8 there's been reports that the observer might bugsplat when closing SU - though I think there are certain conditions for this...
                        • TIGT Online
                          I have a tool that adds an instance of the observer to every instance of every definition [it also tries to remove them first in case they already have them] - I know it's adding as it returns a message in the console as it does it.... BUT then when I open a group/instance it does NOT return a value at all! [e.g. puts instance] - this is on PC not OSX...
                            But with the bare bone example in the API - which you refereed to - does that work for you?
                            Would it not be easier to use the ModelObserver for this? http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onActivePathChanged
                            • TIGT Online
                              Perhaps.
                              My InstanceObserver is only half-working - perhaps my code is flaky ?
                              Watch this space...
                              • TIGT Online
                                I now have it working properly - I'll post something asap...
                                • TIGT Online
                                  Here it is http://forums.sketchucation.com/viewtopic.php?p=280618#p280618
                                  • david_hD Offline
                                    david_h
                                    oh yeah baby!!! I can't wait for this one!
                                    πŸ˜†
