    ACad Colors 2 RGB
    8 Posts 3 Posters 735 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      I have been programing SU materials, and had difficulty finding on line, an array of ACad color numbers along with their corresponding RGB values. I keyed it from scratch, and posted here for anyone that may be interested. Each line in the array has 4 values, the ACad number, then the red, green, and blue values.acad_colors_rgb.txtConceptually, can anyone tell me how to access an existing SU material in order to apply in to a face? Or, to add them to model.materials? I looked at the api, and tried several. without success. The closest I got was:
      materials = model.materials material_current = "C:\\*Path*\\image name.png"
      that created a empty (unusable?) material in model.material. The only method I thought might work, is material.texture="*.jpg", but the api example points to an image, not a skm.
        model.materials is where you gain access to the materials.
        If you know it name, then you can use model.materials['my material']
        You can of course iterate the collection
        model.materials.each { |m|
        model.materials.add
        http://code.google.com/apis/sketchup/docs/ourdoc/materials.html#add
        You can't load or save .skm file via the ruby API.
        • TIGT Online
          I have been programing SU materials, and had difficulty finding on line, an array of ACad color numbers along with their corresponding RGB values. I keyed it from scratch, and posted here for anyone that may be interested. Each line in the array has 4 values, the ACad number, then the red, green, and blue values.[attachment=0:300tej3g]<!-- ia0 -->acad_colors_rgb.txt<!-- ia0 -->[/attachment:300tej3g]Conceptually, can anyone tell me how to access an existing SU material in order to apply in to a face? Or, to add them to model.materials? I looked at the api, and tried several. without success. The closest I got was:
          You could have more simply cribbed it from part of my DXFlayer tool πŸ˜’
          def DXFlayercols;;color_lookup(color)
          ### lookup table of aci,r,g,b
          "1,255,0,0
          2,255,255,0
          3,0,255,0
          4,0,255,255
          5,0,0,255
          6,255,0,255
          7,255,255,255
          8,65,65,65
          9,128,128,128
          10,255,0,0
          11,255,170,170
          12,189,0,0
          13,189,126,126
          14,129,0,0
          15,129,86,86
          16,104,0,0
          17,104,69,69
          18,79,0,0
          19,79,53,53
          20,255,63,0
          21,255,191,170
          22,189,46,0
          23,189,141,126
          24,129,31,0
          25,129,96,86
          26,104,25,0
          27,104,78,69
          28,79,19,0
          29,79,59,53
          30,255,127,0
          31,255,212,170
          32,189,94,0
          33,189,157,126
          34,129,64,0
          35,129,107,86
          36,104,52,0
          37,104,86,69
          38,79,39,0
          39,79,66,53
          40,255,191,0
          41,255,234,170
          42,189,141,0
          43,189,173,126
          44,129,96,0
          45,129,118,86
          46,104,78,0
          47,104,95,69
          48,79,59,0
          49,79,73,53
          50,255,255,0
          51,255,255,170
          52,189,189,0
          53,189,189,126
          54,129,129,0
          55,129,129,86
          56,104,104,0
          57,104,104,69
          58,79,79,0
          59,79,79,53
          60,191,255,0
          61,234,255,170
          62,141,189,0
          63,173,189,126
          64,96,129,0
          65,118,129,86
          66,78,104,0
          67,95,104,69
          68,59,79,0
          69,73,79,53
          70,127,255,0
          71,212,255,170
          72,94,189,0
          73,157,189,126
          74,64,129,0
          75,107,129,86
          76,52,104,0
          77,86,104,69
          78,39,79,0
          79,66,79,53
          80,63,255,0
          81,191,255,170
          82,46,189,0
          83,141,189,126
          84,31,129,0
          85,96,129,86
          86,25,104,0
          87,78,104,69
          88,19,79,0
          89,59,79,53
          90,0,255,0
          91,170,255,170
          92,0,189,0
          93,126,189,126
          94,0,129,0
          95,86,129,86
          96,0,104,0
          97,69,104,69
          98,0,79,0
          99,53,79,53
          100,0,255,63
          101,170,255,191
          102,0,189,46
          103,126,189,141
          104,0,129,31
          105,86,129,96
          106,0,104,25
          107,69,104,78
          108,0,79,19
          109,53,79,59
          110,0,255,127
          111,170,255,212
          112,0,189,94
          113,126,189,157
          114,0,129,64
          115,86,129,107
          116,0,104,52
          117,69,104,86
          118,0,79,39
          119,53,79,66
          120,0,255,191
          121,170,255,234
          122,0,189,141
          123,126,189,173
          124,0,129,96
          125,86,129,118
          126,0,104,78
          127,69,104,95
          128,0,79,59
          129,53,79,73
          130,0,255,255
          131,170,255,255
          132,0,189,189
          133,126,189,189
          134,0,129,129
          135,86,129,129
          136,0,104,104
          137,69,104,104
          138,0,79,79
          139,53,79,79
          140,0,191,255
          141,170,234,255
          142,0,141,189
          143,126,173,189
          144,0,96,129
          145,86,118,129
          146,0,78,104
          147,69,95,104
          148,0,59,79
          149,53,73,79
          150,0,127,255
          151,170,212,255
          152,0,94,189
          153,126,157,189
          154,0,64,129
          155,86,107,129
          156,0,52,104
          157,69,86,104
          158,0,39,79
          159,53,66,79
          160,0,63,255
          161,170,191,255
          162,0,46,189
          163,126,141,189
          164,0,31,129
          165,86,96,129
          166,0,25,104
          167,69,78,104
          168,0,19,79
          169,53,59,79
          170,0,0,255
          171,170,170,255
          172,0,0,189
          173,126,126,189
          174,0,0,129
          175,86,86,129
          176,0,0,104
          177,69,69,104
          178,0,0,79
          179,53,53,79
          180,63,0,255
          181,191,170,255
          182,46,0,189
          183,141,126,189
          184,31,0,129
          185,96,86,129
          186,25,0,104
          187,78,69,104
          188,19,0,79
          189,59,53,79
          190,127,0,255
          191,212,170,255
          192,94,0,189
          193,157,126,189
          194,64,0,129
          195,107,86,129
          196,52,0,104
          197,86,69,104
          198,39,0,79
          199,66,53,79
          200,191,0,255
          201,234,170,255
          202,141,0,189
          203,173,126,189
          204,96,0,129
          205,118,86,129
          206,78,0,104
          207,95,69,104
          208,59,0,79
          209,73,53,79
          210,255,0,255
          211,255,170,255
          212,189,0,189
          213,189,126,189
          214,129,0,129
          215,129,86,129
          216,104,0,104
          217,104,69,104
          218,79,0,79
          219,79,53,79
          220,255,0,191
          221,255,170,234
          222,189,0,141
          223,189,126,173
          224,129,0,96
          225,129,86,118
          226,104,0,78
          227,104,69,95
          228,79,0,59
          229,79,53,73
          230,255,0,127
          231,255,170,212
          232,189,0,94
          233,189,126,157
          234,129,0,64
          235,129,86,107
          236,104,0,52
          237,104,69,86
          238,79,0,39
          239,79,53,66
          240,255,0,63
          241,255,170,191
          242,189,0,46
          243,189,126,141
          244,129,0,31
          245,129,86,96
          246,104,0,25
          247,104,69,78
          248,79,0,19
          249,79,53,59
          250,51,51,51
          251,80,80,80
          252,105,105,105
          253,130,130,130
          254,190,190,190
          255,255,255,255".each{|a|
            rgb=a.split(",")
            if rgb[0].to_i==color
              rgb.shift
              return rgb
            end#if
          end#def
          You can't [yet] access .skm files through the API.
          You can add a material to the model.materials by name...
          mat=model.materials.add("NewMaterial") if not mat=model.materials["NewMaterial"]
          This uses it if it exists or makes it otherwise... it avoids making a duplicate like 'NewMaterial-1'
          You then set the properties of that 'mat' with methods like...
          ` ### several ways of specifying the color
          mat.color=[0,200,100]
          mat.color="Red"
          etc
          mat.alpha=0.5
          mat.texture="C:\Temp\Textures\NewMaterial.png"`
            honoluludesktop
            OK fellows, bummer about skm, and darn google bot, "too-bad for me" about "DXFlayer". Thanks for directions regarding the other "stuff". That's a lot of work to create a complete texture, but when I think about, it should be.
            From this, my understanding is that the materials in the other SU folders that are part of the materials folder, can not be currently accessed by api methods.
              honoluludesktop
              Btw, anyone have a simple Acad dxf that includes sketchup equivalent textures, alpha, and materials/colors; not just the 256 colors.
              • TIGT Online
                Correct - external .skm files [materials] that are not already materials in the model are not accessible through the API to 'load'.
                Neither are there any methods to 'save' materials out as .skm files.
                Because a .skm file is only a re-suffixed .zip file containing some .xml files and the texture image file and thumbnail in theory you COULD both load and save .skm files using various 'zip' methods available for Ruby...
                To 'import' a .skm you'd copy the external .skm file and rename it as a .zip in a temp-folder, then extract its contents, parse the .xml files for name, color, alpha etc; then duplicate these for a new [or existing] material in the model.materials with that name, [re]setting its color, alpha etc and finally add the texture file to it if appropriate [remember that a .skm file can just specify a 'color' without a texture]...
                To 'export' a model's material to an external .skm you'd make a temp-folder and make appropriate .xml files in it using the correct format - including the material's name, color, alpha etc, if it has a texture you would also use a texturewriter to export the material's texture as an image file into the set [making the thumbnail image is another issue?]; finally you make a new .zip file from this set of files and rename it as a .skm to suit...
                I've played a little with Ruby and 'zip' files and I know Thomthom is also looking at it [for some nefarious purpose] - so far I don't think any one has made the 'skm_import' and 'skm_export' methods... But it is certainly possible...
                If we wait for it to be added to the API by Google we could all be a lot grayer when it arrived...
                  Just learned a new word today. πŸ˜„ "nefarious" πŸ‘Ώ
                  Once we find a good solution for reading & writing ZIP files on both platforms, that is lightweight, doesn't have other dependancies so it's easy to distribute I'm sure we'll quickly have code to read .skm.
                  As for writing, we also need to write thumbnails, as TIG says. Another troublesome area where we are lacking - image manipulation.
                    honoluludesktop
                    I unzipped a skm to see what it contained. If I learn enough, maybe working with skm's is something I can attempt to tackle a year from now?-)
