    I've reinstalled Version 6.
    13 Posts 4 Posters 1.6k Views 4 Watching
    • John SayersJ Offline
      John Sayers
      Since I installed Version 8 I've had all sorts of problems. the pushpull is weird, i.e. it selects the wrong face, the mouse is weird - I have to add an additional click sometimes to make something like a simple delete happen, I can't capture a group of items as they highlight then unhighlight when I click delete, sometimes it appears the mouse is one step behind me and it appears to have infected version 7 as well which now shows similar symptoms. (I'm on a PC BTW)
      I've checked my computer for Trojans and viruses etc and it's clean. I've tried switching off the acceleration but it makes no difference.
      So I reinstalled version 6 and I think I'll go back to it. I can't find my copy of version 5 else I would have reverted back to it and 5 is no longer a download option, only 6 and 7.
      Version 6 works fine with none of the above problems, it's also more intuitive.
      I don't use the program in conjunction with Google earth so I have no need for the the updates, I don't use fancy styles, renders or street view scenes either. I just use it to make 3D models of my designs so I can show my client and export to .dwg for the 2D plans. I don't use layout as I have ProgeCad.
        Why all the way back to SU6? Why not SU7?
        As for the issues: PushPull in SU8 allows you to pre-select faces before pushpulling. You might be running into this.
        As for other issues you have - newer SU versions demands better graphic card drivers as they use other OpenGL commands - have you updated your graphic card drivers recently?
          John Sayers
          yes - I have the latest video card driver.
            John Sayers
            Problem solved - I reinstalled a video driver from 2008 and all the problems have gone away. I hadn't seen the notice regarding Nvidia drivers.
            So I'm now back to running V8.
              What notice?
                John Sayers
                Error 404 (Not Found)!!1
                (groups.google.com)
                  Odd...
                  I have an nVidia GeForce 8800 GT - no issues at all.
                  Maybe it's an XP thing... I'm running Win7.
                    John Sayers
                    Yes - I think it's an XP thing as you say.
                      tfdesign
                      In all fairness, XP is a dead operating system. Here in the UK, it seems that many still haven't updated to 7, and as a result I'm producing stuff that some corporations (especially education & council based), can't use, because they still have to update. It's very frustrating. I wish everybody would upgrade to W7! 😑
                      My book "Let's SketchUp!" Download from here
                      • honoluludesktopH Offline
                        honoluludesktop
                        Tom, What kinds of apps. run on Win7, but not on WinXP? The only thing I could think of deals with hardware, whose drivers for Win7 have no equivalent for WixXP.
                          tfdesign
                          It's nothing to do with the apps (if they are up-to-date), more to do with investment in newer technologies (those apps not being up-to-date), for example, I am sent a load of MPG-2 files which Quicktime won't touch. These were created with some out of date application that was installed with XP on their PC's a few years back. The only thing that will play them is the VLC player. Great. I can playback, but I can't edit, or update, without myself having to spend even more money (which I haven't got).
                          It's lazy British IT basically, "if it works, don't fix it" type attitude, which is fine, if that whole department doesn't update, but your scr*wed if anything leaves the room. Generally it seems that applications don't get updated unless the operating system gets a boost.
                          Another interesting example was a department I was working in recently where CS5 kept crashing badly on XP. But after a whole load of internet searching, it was found that updating to Windows 7 was curing most peoples problems. The department updated only one PC to W7, and the problem went away. πŸ˜’
                          Okay, they probably just need to update their apps, but many IT departments' budgets don't appear to stretch this far- at least in England. I think IT departments in the USA are far better at this and more 'on the ball' than we are! πŸ˜† 😞
                            John Sayers
                            Nvidia have just released (2010/10/25) a new XP Nvidia driver. It now works with Sketchup.
                            http://www.nvidia.com/object/winxp-260.99-whql-driver.html
                              honoluludesktop
                              Tom, I understand your frustration as a service provider, but I wouldn't want the State buy new cars just because the old ones don't have a video camera providing a view backing up. Aren't the Brit's currently climbing out of one of the worlds worst economic turn downs? Hope you can "hang in there" until things get better.
