    Componnent Replacer
    25 Posts 4 Posters 2.8k Views 4 Watching
    • E Offline
      ericschimel
      Does anyone know of a plugin that can find all instances of a component, and replace them with a new one of the users choice?
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        You can use Selection Toys to select all instances in a model (if you Select All instead of Select Active) then you can use the Component Browser to replace them.
        • E Offline
          ericschimel
          Here's a tricky one for you, when you have DC, and it resizes a component that is one of its children, it renames if by adding a number after it. For example, if you have a cabinet, and one of its child components is a door, and you have two of the same cabinet, but you have resized it, and the DC resized the doors, you now have "DOOR" and "DOOR#1" for components.
          If I wanted to select all the doors, is there a way that a plugin could select them based on part of the name?
          -Eric
          Custom Models
            Selection Toys πŸ˜‰
            There's a own sub-menu for DC components.
            • E Offline
              ericschimel
              Ok, I'll have to try that one again. The last time I used it, I don't think there was such a feature... But it was a while ago...
              Thanks again Thomthom!
              -Eric
              Custom Models
                It's one of the very early functions. But it's only available from the context menu.
                • E Offline
                  ericschimel
                  Its not working for me. Remember that the components I am trying to select are children of their parent DC. When the Parent DC changes the children, each child gets a number added to its name, therefore making it a different component in the eyes of Sketchup.
                  Is there a way that I can select components with a wildcard? Say "DOOR*" so that all components that start with the name DOOR will be selected, regardless of what follows in their names?
                  -Eric
                  Custom Models
                    Yes - Selection Toys handles this. I reads the attributes of the DC to determine which DC the instances inherit from.
                    • E Offline
                      ericschimel
                      Yup, I did that, it doesn't select anything else, either a child, or a parent.
                      These DC's that I use get a name change the second I modify them in any way....
                      So even though I have two DC's that have the same name (Like Single Door Wall Cabinet) they aren't the same component after I changes the DC options for one. They are in my model as separate components, with separate names.
                      When I choose that option in your tool on one of the wall cabinets, it won't select the others.
                      If I have identical copies of DC's (ones that are identical in every way) then I can select both using that method.
                      -Eric
                      Custom Models
                        Can you post a sample model?
                        I'm not seeing any issues selecting DCs of the same type.
                        • E Offline
                          ericschimel
                          There you go, should be pretty self explanatory when you open it.
                          Thanks for looking!
                          Selction Toys Example.skp
                          -Eric
                          Custom Models
                            I have no problems selecting the DC.
                            Are you sure you are not using the "Instances" instead of the "DC Instances" sub menu?
                            Observe my last screenshot.
                            • E Offline
                              ericschimel
                              When I do "Instances" and "Select active" on the two identical pulls, they both get highlight. When I go to "DC instances" and then to "Select Active, it highlights every component and group in the model.
                              In that example I sent you, I want to be able to click on, and select all those pieces of hardware, even though I have changed the options in one of them.
                              -Eric
                              Custom Models
                                ugh... seems to be a bug here...
                                  Found the cursed bug! I'd missed an underscore character... 😳
                                  I'll upload a patch tomorrow.
                                  • E Offline
                                    ericschimel
                                    I am glad it was easy for you, I was just hoping that it wasn't me being stupid!
                                    -Eric
                                    Custom Models
                                    • E Offline
                                      ericschimel
                                      Let me know when you upload it. I'll be the first to try it out! πŸ˜„
                                      -Eric
                                      Custom Models
                                      • bmikeB Offline
                                        bmike
                                        Stumbled on this... sounds like what I need (although I would use it infrequently)!
                                        I'll watch for a bug fix.
                                        Can you post a link back to the original when you have time to get it updated?
                                        mike beganyi design + consulting llc
                                          http://forums.sketchucation.com/viewtopic.php?f=323&t=14975
                                          • E Offline
                                            ericschimel
                                            I am getting this:
                                            -Eric
                                            Custom Models
                                            • 1 / 2
