    Componnent Replacer
    25 Posts 4 Posters 2.0k Views 4 Watching
      Selection Toys πŸ˜‰
      There's a own sub-menu for DC components.
      • E Offline
        ericschimel
        Ok, I'll have to try that one again. The last time I used it, I don't think there was such a feature... But it was a while ago...
        Thanks again Thomthom!
        -Eric
        http://plugin.sketchthis.net
        Sketchup Kitchen Design Plugin
        Custom Models
          It's one of the very early functions. But it's only available from the context menu.
          • E Offline
            ericschimel
            Its not working for me. Remember that the components I am trying to select are children of their parent DC. When the Parent DC changes the children, each child gets a number added to its name, therefore making it a different component in the eyes of Sketchup.
            Is there a way that I can select components with a wildcard? Say "DOOR*" so that all components that start with the name DOOR will be selected, regardless of what follows in their names?
            -Eric
            Custom Models
              Yes - Selection Toys handles this. I reads the attributes of the DC to determine which DC the instances inherit from.
              • E Offline
                ericschimel
                Yup, I did that, it doesn't select anything else, either a child, or a parent.
                These DC's that I use get a name change the second I modify them in any way....
                So even though I have two DC's that have the same name (Like Single Door Wall Cabinet) they aren't the same component after I changes the DC options for one. They are in my model as separate components, with separate names.
                When I choose that option in your tool on one of the wall cabinets, it won't select the others.
                If I have identical copies of DC's (ones that are identical in every way) then I can select both using that method.
                -Eric
                Custom Models
                  Can you post a sample model?
                  I'm not seeing any issues selecting DCs of the same type.
                  • E Offline
                    ericschimel
                    There you go, should be pretty self explanatory when you open it.
                    Thanks for looking!
                    Selction Toys Example.skp
                    -Eric
                    Custom Models
                      I have no problems selecting the DC.
                      Are you sure you are not using the "Instances" instead of the "DC Instances" sub menu?
                      Observe my last screenshot.
                      • E Offline
                        ericschimel
                        When I do "Instances" and "Select active" on the two identical pulls, they both get highlight. When I go to "DC instances" and then to "Select Active, it highlights every component and group in the model.
                        In that example I sent you, I want to be able to click on, and select all those pieces of hardware, even though I have changed the options in one of them.
                        -Eric
                        Custom Models
                          ugh... seems to be a bug here...
                            Found the cursed bug! I'd missed an underscore character... 😳
                            I'll upload a patch tomorrow.
                            • E Offline
                              ericschimel
                              I am glad it was easy for you, I was just hoping that it wasn't me being stupid!
                              -Eric
                              Custom Models
                              • E Offline
                                ericschimel
                                Let me know when you upload it. I'll be the first to try it out! πŸ˜„
                                -Eric
                                Custom Models
                                • bmikeB Offline
                                  bmike
                                  Stumbled on this... sounds like what I need (although I would use it infrequently)!
                                  I'll watch for a bug fix.
                                  Can you post a link back to the original when you have time to get it updated?
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=14975
                                    • E Offline
                                      ericschimel
                                      I am getting this:
                                      -Eric
                                      Custom Models
                                          Type load 'tt_selection_toys.rb' in the Ruby console and post back the full message.
                                            Never mind - I realised what it was.
                                            Download again.
