    Componnent Replacer
    25 Posts 4 Posters 2.8k Views 4 Watching
    • E Offline
      ericschimel
      Ok, I'll have to try that one again. The last time I used it, I don't think there was such a feature... But it was a while ago...
      Thanks again Thomthom!
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        It's one of the very early functions. But it's only available from the context menu.
        • E Offline
          ericschimel
          Its not working for me. Remember that the components I am trying to select are children of their parent DC. When the Parent DC changes the children, each child gets a number added to its name, therefore making it a different component in the eyes of Sketchup.
          Is there a way that I can select components with a wildcard? Say "DOOR*" so that all components that start with the name DOOR will be selected, regardless of what follows in their names?
          -Eric
          Custom Models
            Yes - Selection Toys handles this. I reads the attributes of the DC to determine which DC the instances inherit from.
            • E Offline
              ericschimel
              Yup, I did that, it doesn't select anything else, either a child, or a parent.
              These DC's that I use get a name change the second I modify them in any way....
              So even though I have two DC's that have the same name (Like Single Door Wall Cabinet) they aren't the same component after I changes the DC options for one. They are in my model as separate components, with separate names.
              When I choose that option in your tool on one of the wall cabinets, it won't select the others.
              If I have identical copies of DC's (ones that are identical in every way) then I can select both using that method.
              -Eric
              Custom Models
                Can you post a sample model?
                I'm not seeing any issues selecting DCs of the same type.
                • E Offline
                  ericschimel
                  There you go, should be pretty self explanatory when you open it.
                  Thanks for looking!
                  Selction Toys Example.skp
                  -Eric
                  Custom Models
                    I have no problems selecting the DC.
                    Are you sure you are not using the "Instances" instead of the "DC Instances" sub menu?
                    Observe my last screenshot.
                    • E Offline
                      ericschimel
                      When I do "Instances" and "Select active" on the two identical pulls, they both get highlight. When I go to "DC instances" and then to "Select Active, it highlights every component and group in the model.
                      In that example I sent you, I want to be able to click on, and select all those pieces of hardware, even though I have changed the options in one of them.
                      -Eric
                      Custom Models
                        ugh... seems to be a bug here...
                          Found the cursed bug! I'd missed an underscore character... 😳
                          I'll upload a patch tomorrow.
                          • E Offline
                            ericschimel
                            I am glad it was easy for you, I was just hoping that it wasn't me being stupid!
                            -Eric
                            Custom Models
                            • E Offline
                              ericschimel
                              Let me know when you upload it. I'll be the first to try it out! πŸ˜„
                              -Eric
                              Custom Models
                              • bmikeB Offline
                                bmike
                                Stumbled on this... sounds like what I need (although I would use it infrequently)!
                                I'll watch for a bug fix.
                                Can you post a link back to the original when you have time to get it updated?
                                  404 Not Found
                                  (forums.sketchucation.com)
                                  • E Offline
                                    ericschimel
                                    I am getting this:
                                    -Eric
                                    Custom Models
                                        Type load 'tt_selection_toys.rb' in the Ruby console and post back the full message.
                                          Never mind - I realised what it was.
                                          Download again.
                                          • E Offline
                                            ericschimel
                                            Brilliant. It works perfectly now Thomthom!
                                            -Eric
                                            Custom Models
