    Componnent Replacer
    25 Posts 4 Posters 2.0k Views 4 Watching
    • E Offline
      ericschimel
      Here's a tricky one for you, when you have DC, and it resizes a component that is one of its children, it renames if by adding a number after it. For example, if you have a cabinet, and one of its child components is a door, and you have two of the same cabinet, but you have resized it, and the DC resized the doors, you now have "DOOR" and "DOOR#1" for components.
      If I wanted to select all the doors, is there a way that a plugin could select them based on part of the name?
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        Selection Toys πŸ˜‰
        There's a own sub-menu for DC components.
        • E Offline
          ericschimel
          Ok, I'll have to try that one again. The last time I used it, I don't think there was such a feature... But it was a while ago...
          Thanks again Thomthom!
          -Eric
          Custom Models
            It's one of the very early functions. But it's only available from the context menu.
            • E Offline
              ericschimel
              Its not working for me. Remember that the components I am trying to select are children of their parent DC. When the Parent DC changes the children, each child gets a number added to its name, therefore making it a different component in the eyes of Sketchup.
              Is there a way that I can select components with a wildcard? Say "DOOR*" so that all components that start with the name DOOR will be selected, regardless of what follows in their names?
              -Eric
              Custom Models
                Yes - Selection Toys handles this. I reads the attributes of the DC to determine which DC the instances inherit from.
                • E Offline
                  ericschimel
                  Yup, I did that, it doesn't select anything else, either a child, or a parent.
                  These DC's that I use get a name change the second I modify them in any way....
                  So even though I have two DC's that have the same name (Like Single Door Wall Cabinet) they aren't the same component after I changes the DC options for one. They are in my model as separate components, with separate names.
                  When I choose that option in your tool on one of the wall cabinets, it won't select the others.
                  If I have identical copies of DC's (ones that are identical in every way) then I can select both using that method.
                  -Eric
                  Custom Models
                    Can you post a sample model?
                    I'm not seeing any issues selecting DCs of the same type.
                    • E Offline
                      ericschimel
                      There you go, should be pretty self explanatory when you open it.
                      Thanks for looking!
                      Selction Toys Example.skp
                      -Eric
                      Custom Models
                        I have no problems selecting the DC.
                        Are you sure you are not using the "Instances" instead of the "DC Instances" sub menu?
                        Observe my last screenshot.
                        • E Offline
                          ericschimel
                          When I do "Instances" and "Select active" on the two identical pulls, they both get highlight. When I go to "DC instances" and then to "Select Active, it highlights every component and group in the model.
                          In that example I sent you, I want to be able to click on, and select all those pieces of hardware, even though I have changed the options in one of them.
                          -Eric
                          Custom Models
                            ugh... seems to be a bug here...
                              Found the cursed bug! I'd missed an underscore character... 😳
                              I'll upload a patch tomorrow.
                              • E Offline
                                ericschimel
                                I am glad it was easy for you, I was just hoping that it wasn't me being stupid!
                                -Eric
                                Custom Models
                                • E Offline
                                  ericschimel
                                  Let me know when you upload it. I'll be the first to try it out! πŸ˜„
                                  -Eric
                                  Custom Models
                                  • bmikeB Offline
                                    bmike
                                    Stumbled on this... sounds like what I need (although I would use it infrequently)!
                                    I'll watch for a bug fix.
                                    Can you post a link back to the original when you have time to get it updated?
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=14975
                                      • E Offline
                                        ericschimel
                                        I am getting this:
                                        -Eric
                                        Custom Models
                                            Type load 'tt_selection_toys.rb' in the Ruby console and post back the full message.
