    [Plugin] exportlayers2daes
    4 Posts 3 Posters 4.1k Views 3 Watching
    • TIGT Online
      (c) TIG 2010
      Permission to use, copy, modify, and distribute this software for
      any purpose and without fee is hereby granted, provided that the above
      copyright notice appear in all copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      exportlayers2daes.rb >>> ../Plugins/ folder
      Purpose:
      It exports everything in the Model's entities on each 'Layer' as a separate
      Collada '.dae' file.
      Usage:
      To run the tool type 'exportlayers2daes' in the Ruby Console.
      If the Model SKP is new and has not yet been saved you will get an error.
      Layers are NOT exported if they are switched 'off'.
      Layers are NOT exported if they do not contain 'entities'.
      All eligible Layers are processed in turn.
      The DAE file path in displayed in the Console.
      The DAE files are exported into the Model's folder.
      They are named after the Layer.
      'Layer0.dae'
      'Furniture.dae'
      'Site.dae'
      The 'file_name' is based on the 'layer_name' but with any unacceptable
      characters removed [it only uses: A-Za-z0-9_]; if this would duplicate a
      name then an incrementing numerical suffix is added - e.g. 'Site_001.dae'.
      On completion the total number of Layers exported as DAEs is reported.
      Note that you can change the DAE export options in the rb_file itself -
      except for 'selectionset_only' which must always be set as 'true'.
      Donations:
      by PayPal to info @ revitrev.org PayPalButton ___________________________________________________________________________
      Version:
      1.0 20101010 First release.
      • K Offline
        Khai
        thanks TIG πŸ˜„
        • TIGT Online
          Pilou - correct - avoid accents etc in folder_paths... πŸ˜’
            I suppose there is the same problem of accents for French Windows systΓ¨me ? πŸ˜‰
            So If I use a path without accent that will be ok β˜€
            Ps I have now more 300 simple Plugs without count the folders πŸ˜’
            You will kill my old 1 Giga memory πŸ’š
            Edit that works! 😎 πŸ‘
