    Basic modelling in Vray Sketchup
    renderpluginsextensions
    3 Posts 3 Posters 1.2k Views 3 Watching
    • W Offline
      Willow13
      SU Version: 6.0.1099
      Vray Version: 1.49.84
      Having a very basic but frustrating problem atm. In the past when I have assigned vray materials to my model and gone to render they have come out fine, but on my latest concept I seem to have missed out a step and find myself with some invisible groups, components and surfaces! If anyone could direct me towards a basic "material assigner for Vray noobs" tutorial that would be great.
      I've checked this post out (http://forums.sketchucation.com/viewtopic.php?f=322&t=18865&p=154503&hilit=assign+materials+vray#p154503), is the fact im applying materials to group/components and not faces the problem?
      Cheers all
        "Vray Version: 1.49.84" - this isn't a real VfSU version number. Are you getting this number from the VFB along with the render time info? (that version number is not refering to the VfSU version. You need to look in the about section of VfSU if you are using the old VfSU (which I think you are) or in Window > Preferences > Extensions if you are using the latest.)
        The older VfSU versions has some issues where it would not render groups in some cases. Depending on what version you have you might only need to reload the model.
        (btw - why are you using such an old SU version - you're not even using the latest service release of SU6. That could also be causing problems...)
        • G Offline
          gG_hazirah
          i know how to overcome this prob.. u juz save the file after u set all the colour n materials. then off the file.. n then open it back.. then u start render using vray. it works for me since i faced the same problem as well bfore.. give it a try.. n good luck!
