    Ripples In Water
    10 Posts 7 Posters 1.9k Views 7 Watching
    • E Offline
      ericschimel
      Does anyone out there know of an easy way to make a surface shaped like ripples in water? I tried using the sandbox and smoove, and I can get a reasonable approximation of what I am looking for, but its not the easiest approach.
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
      • soloS Offline
        solo
        Tried SDS? (subdivide and smooth)
        If you are rendering then a displacement map would work great.
        http://www.solos-art.com
          • david_hD Offline
            david_h
            Somebody posted a pretty cool example using TT's Bitmap2Mesh plugin.
              That'd be Jeff's post?
              http://forums.sketchucation.com/viewtopic.php?f=323&t=31339&start=15#p275962
              http://forums.sketchucation.com/download/file.php?id=55637&t=1
              But bewarned - it'd probably a very dense mesh.
              But didn't Whaat have a polyreducer tool in one of this hits?
              Or you can try with a very small heightmap.
              • E Offline
                ericschimel
                Thanks ThomThom, I love the follow me example, I think that is going to work best for what I am trying to accomplish.
                Your bitmap to mesh plugin is pretty cool as well, I am going to check that out. It could be useful for renders!
                -Eric
                Custom Models
                • DavidBoulderD Offline
                  DavidBoulder
                  If you just care about this for still renderings, then there was a great Photoshop plugin by flamingpear called flood that does a great job for still images. You have a lot of control over the perspective and type of ripples on the surface.
                  http://www.flamingpear.com/flood.html
                  David Goldwasser
                  OpenStudio Developer
                  • daleD Offline
                    dale
                    I believe there is also a script for Gimp called if I remember correctly, Water reflection displacement map generator.
                      Also there is Sqirlz Water reflections (free) both for stills and movies / animated gif's
                      • E Offline
                        ericschimel
                        Oh yeah, I totally forgot about that one! Thanks!
                        -Eric
                        Custom Models
