    Bottle label
    8 Posts 5 Posters 5.7k Views 5 Watching
    • A
      annovi.frizio
      hi sorry my bad english, i search a tutorial for draw a bottle label (cilinder) in sketchup (sample. http://www.candybarwrap.com/images/lilly_wedding_sample.jpg) please help me, thank you, regards πŸ˜„
      • TIGT
        Here's one for a label onto a curved surface - you can apply the ideas to a single curved bottle.
        [flash=480,385:csg6m38g]http://www.youtube.com/v/HHsRRLCAOm8?fs=1&hl=en_GB[/flash:csg6m38g]
        To make the bottle itself draw a circle for its plan and a half section face - followme the section around the circle, add transparent material etc...
        • TIGT
          Here's an alternative to using a 'projected-texture' - it's a 'wrapping' method http://forums.sketchucation.com/viewtopic.php?p=100569#p100569
          • GaieusG
            As long as the projection does not go too much around the object you are projecting it onto, it is fine as the distortion on the sides is not that visible.
            Once it goes too much onto the sides however,the wrapping method is much more preferred (though bit more laborious) and in any case, it gives a much more precise result.
            • A
              annovi.frizio
              ok, I look, thank you.. πŸ˜„. this is only my second day in sketchup, sorry πŸ˜„
              • GaieusG
                No problem, Fabricio. We all started somewhere! I still remember when I discovered SketchUp some 4+ years ago...
                πŸ˜‰
                • numbthumbN
                  numbthumb
                  Hi, frizio
                  Assuming that you have already made a bottle, you can wrap your texture around it - check out this thread for some additional info
                  http://forums.sketchucation.com/viewtopic.php?f=79&t=21762&start=15
                  http://forums.sketchucation.com/viewtopic.php?f=15&t=13564&p=100523&hilit=wrap+label#p100523
                  Comfortably numb...
                  • N
                    notmy
                    HI,
                    Is there anyone able to help me in applying graphics on the can, but the rest of the can, it should be in aluminum. (Like REDBULL cans)
                    I have something like this (left):
                    http://freshdrink.pl/klient/Mini_cans.jpg
                    but it has to be something like this but white should be cans color (right).
                    It`s any video tut or someone can help me step by step? πŸ˜„
