    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Select all attached
    13 Posts 5 Posters 1.1k Views 5 Watching
      crabbeapple
      I cant make a select/ select all attached/ shortcut key in sk/up8 that I have used with previous versions, can someone help with this on with a plugin that will allow me to make shortcut key. thanks
        A triple click on an entity with the Select tool will select all attached. Why not use that?
        Or, if you need a keyboard shortcut, Draw something such as a box in the drawing window and select part of it. then you should be able to find Edit/Item/Select/All Connected.
        • Chris FullmerC Offline
          And, you can still set a shortcut for select all connected. But you need to have a face selected when you go into the shortcut manager. If you do not have a face (or edge) selected, then the option to set a shortcut to "all connected" does not appear.
          Chris
          All my Plugins I've written
            You put that better than I did, Chris. Thank you.
              😳 I think I read your first paragraph and skipped the 2nd. I did not realize that you had already explained that - sorry Dave!
                Chris, no need to apologize. You did explain it better. 👍
                And why aren't you asleep? 😄
                  Coding into the wee hours of the night again? What's the new project?
                  • mitcorbM Offline
                    mitcorb
                    @ThomThom:
                    What about your post time? It can't be beer that's keeping you up 😆
                      ? at 13:48 ?
                      • mitcorbM Offline
                        mitcorb
                        @ThomThom
                        My page says you posted at 4:20 am. Obviously it is the time zone settings that are confusing me. Just so long as you get your "beauty sleep". 😆 😆
                          I do spend too much time - but not that much!
                          • mitcorbM Offline
                            mitcorb
                            By the way, what does Dave R's signature line mean?
                            Something about clocks, logons, taskbars?? 😆 😆
                            • mitcorbM Offline
                              mitcorb
                              here's a project for those with nothing else to do:
                              Make multiple instances of the same emoticons move out of sync. I've got no clue.
