    Does layout not support hidden lines?
    layout
    25 Posts 10 Posters 9.9k Views 10 Watching
      bertsminky
      I did the two SU Scenes onto two LO layers and at first it showed perfectly well then after going back to it one of the scenes had become a solid form - ie you couldnt see through it to the other scene/layer behind ?
      Any idea on why this would happen cos it had me scratching my head for a while - in the end i drew a clipping mask but for the backedges example above this wouldnt be suitable.
        Bert, could you post the LO file so we can see? It could be something fairly straightforward.
        • AnssiA Offline
          Anssi
          Dave's method could perhaps be refined:
          • create two identical scenes in SketchUp, one in a style you want, the other in Wireframe, with a white background.
          • In LayOut, overlay the wireframe view on the standard view, and set it to use a Hidden linetype (I don't know if it is necessary to explode it first - my old laptop is too slow to run LayOut well)
          Anssi
          • Y Offline
            Yousefk88
            For me i'm turning off edges in sketchup but they are showing again in layout, and couldnt find a style with there's no edges (out lines)...what to do?
              Perhaps you could share an example? You description isn't very clear. Make a LayOut file that shows what you are talking about and post it.
              • 2 / 2
