    ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
    Please help me fill a curved surface
    8 Posts 6 Posters 1.1k Views
    • frascatiF Offline
      frascati
      This is probably exceedingly simple. But how do I produce a surface on the following cube with curved sides?
      curved sides.skp
        mickath
        Here you go.
        Mickath
        curved sides.skp
        • charly2008C Offline
          charly2008
          Hi Brad,
          take the CurviLoft plugin or Extrude Edges by Loft plugin.
          Charly
          • frascatiF Offline
            frascati
            Thank you very much. I'll try that. I had in the meanwhile discovered that I could just fill panels one segment at a time but this ought to speed things up a whole lot.
            • Jean LemireJ Offline
              Jean Lemire
              Hi folks.
              See this SU file for ideas.
              Curved sides 2.skp
              • EarthMoverE Offline
                EarthMover
                Curviloft Skinning function is very fast for this shape. Explode it at the end and it will retain the sharp edges. (I also reduced sampling and interpolation to reduce the amount of geometry needed, but it's not a necessary step if file size isn't an issue)
                Content Creator at Skapeup
                • jeff hammondJ Offline
                  jeff hammond
                  hey adam..
                  a tip - the words 'sampling' and 'interpolation' are actually written on a button.. click the button to turn it off instead of reducing amount to 0.
                  @jean - nice one!
                  dotdotdot
                    EarthMover
                    Thanks bro...didn't realize that!
