    Lines appear on sanbox terrain
    4 Posts 3 Posters 416 Views 3 Watching
    • D
      danbig
      Hi all -
      This has happened a few times now. Here's what happens.
      1. I create terrain from contours using sandbox.
      2. The terrain initially has all the internal lines hidden (the outside border of the terrain is visisble).
      3. Sometime after I've continued editing, a random smattering of lines across the terrain become unhidden (noted by the blue arrow on screeshot). The lines are actually part of the terrain group. Is there any way to prevent this from happening?
      • EarthMoverE
        EarthMover
        Try turning up the soft/smooth level in the smoothing window. If that doesn't work you can try a search for ThomThom's Selection Toys plugin and select the whole mesh, right click and then choose Select Only > Edges. Then in the entity info box click on soft and smooth. Should get rid of them.
        It happens to me a lot to. Not sure why, but that's how I fix it.
        Content Creator at Skapeup
        • D
          danbig
          Hmmm.
          What I don't get, is why the lines appear in the first place?
          In my case, I haven't edited the terrain (or even opened the group for editing), and the lines still appear.
          • thomthomT
            Did you minimize the SU window while having the terrain selected?
            ...yea - it's an odd little wicked SU bug...
