    [Plugin] Select Curve
    37 Posts 16 Posters 53.3k Views 16 Watching
    • ken28875K
      ken28875
      @thomthom said:
      Ken - what kind of machine are you creating there?? 😲 😮
      Hi Thomas,
      I am working on a time traveling machine. I will go back 15 years ago when I was an architecture student and will create Sketchup so I can do crazy stuff instead of using pencil, markers, spray paints, and tracing paper. 😉
      Just kidding. 😄
      It is for a contest I am doing that is due next month. http://news.deviantart.com/article/128272/
      You can see some of the WIP here: http://forums.sketchucation.com/viewtopic.php?f=81&t=27030
      Have a nice week!
      _KN
      Follow Your Dreams.
      • thomthomT
        Ooh, sweet prices. I don't really pay attention any more what goes on at dA...
        • W
          watkins
          Dear David,
          My usual method is as follows:
          a) Find the centre of the broken circle, and mark with a cpoint.
          b) Using the cpoint, draw a circle over the broken circle and delete any unwanted face so formed.
          c) Use move+copy to move copies of the reconstructed circle entity up/down to recreate other broken circles.
          For point c), think of a simple circular flange and copying the top outer edge to the bottom outer edge (same diameter)using move+copy.
          The above method reconstructs the circle and re-assigns the entity 'circle' to the feature, but it takes time and one has to be careful to delete unwanted faces.
          Yes, I could use weld, but the resulting feature has the assignment 'curve' rather than circle, which excludes the use of 'point at centre', which I use frequently for alignment. Chris Fullmer's Arc Centrepoint Finder has helped enormously, but it would be nice to revolve a shape and have circles formed. Thank you for considering my request.
          Kind regards,
          Bob
          • thomthomT
            So simply drawing an arc or circle over an broken acr/circle mends it? hmmm
            I already have the code to find the centre of exploded curves...
            http://forums.sketchucation.com/viewtopic.php?f=323&t=30506&p=267835&hilit=[Plugin]#p267835
            • winoooW
              winooo
              Awesome,thx
              www.mffw.blogspot.com
              • H
                horizon
                I have managed to install your select curve on my laptop running xp but it will not load on my desktop running win 7... i wonder if there is an issue with it being a 64 bit machine?
                • thomthomT
                  64bit is no issue. I run 64bit Win7.
                  Do you get any errors or anything?
                  • O
                    Orthogon
                    Excellent, works cleanly. But wondering why it isn't added to the right-click context menu, where one usually looks for such things -?
                    • M
                      Mythos
                      Thank you very much for this plugin. I like a lot! I want to propose a little improvement: Would it be possible to let the user even click on a face to automatically select all edges by this tool?
                        Although the "improvement" might be possible, since you'd already have the Select tool active, why not just double click on the face? That would select all of the bounding edges of the face without the added step of activating a plugin.
                        • M
                          Mythos
                          Certainly you are right, but then you have to press SHIFT wait a second (to avoid tripple clicking) and then you have to click again to deselect the face (since you only want the edges be selected). It would be much more convenient to have a curve-only selection tool that even can select the edges of a clicked face.
                          • cottyC
                            cotty
                            A quick way for this: select outer edges (Chris Fullmer) with a shortcut assigned
                            my SketchUp gallery
                            • thomthomT
                              I use Selection Toys to quickly filter out entity types. I have Edges on Ctrl+1 and Faces on Ctrl+2, Groups and Components on Ctrl+3 and Ctrl+4.
                              Then I have Ctrl+Shift+n to deselect. Those shortcuts are easily accessible to my left hand which is always on the keyboard while I model. Quite flexible setup.
                              • M
                                Mythos
                                Nice, I change my hotkeys to use this setup too. But I think it would be very intuitive to have the normal select operation (which selects the face first) and a curve-based select operation (which forcly grabs the edges even if applied on faces). Since the "Select Curve" plugin currently doesn't operate at all on faces it would be just a nice addition that makes the "Select Curve" tool a little bit more powerful.
                                • IltisI
                                  Iltis
                                  Hello @thomthom, thank you very much for this very usefull plugin.
                                  Is there a way to add a modified cursor? (I can draw it if you tell me the specifications.)
                                  • K
                                    KropocLeckor
                                    Hello, thomthom. I used Select Curve mainly on SU2015 and 2016 before I migrated to 2019. I use SelectCurve with a shortcut (Shift+C). But in 2019, when I pressed it, other tool pallets will pop up. Never SelectCurve. Changing Shortcut doesn't change anything. Same tool pallets still pop up. I remove/uninstall that particular plugin. And press again..another tool pallets will pop up. Why this happening? 😕
                                    https://imgur.com/a/Bi2hl0W
                                    Thank you
                                    • IltisI
                                      Iltis
                                      Hi @thomthom and folks,
                                      I just managed to insert custom cursors to this usefull plugin.
                                      Attached are the .png files.
                                      The images are in the same folder than "core.rb"
                                      And this is the code :
                                      def initialize(settings)
                                            @settings = settings
                                      		folder_path = File.dirname(__FILE__)
                                      		cursor_name = 'cursor_select_curve.png'
                                      		cursor_select_curve_path = File.join(folder_path, cursor_name)
                                      	   @result = File.file?(cursor_select_curve_path)
                                      	   unless @result
                                      		  msg = "Can't find the 'cursor icon' path"
                                      		  UI.messagebox(msg, MB_OK)
                                      		  return
                                      		cursor_name = 'cursor_select_curve_plus.png'
                                      		cursor_select_curve_plus_path = File.join(folder_path, cursor_name)
                                      	   @result = File.file?(cursor_select_curve_plus_path)
                                      	   unless @result
                                      		  return
                                      		cursor_name = 'cursor_select_curve_minus.png'
                                      		cursor_select_curve_minus_path = File.join(folder_path, cursor_name)
                                      	   @result = File.file?(cursor_select_curve_minus_path)
                                      	   unless @result
                                      		  return
                                      		cursor_name = 'cursor_select_curve_plus_minus.png'
                                      		cursor_select_curve_plus_minus_path = File.join(folder_path, cursor_name)
                                      	   @result = File.file?(cursor_select_curve_plus_minus_path)
                                      	   unless @result
                                      		  return
                                      		@cursor_select        = UI.create_cursor(cursor_select_curve_path, 9, 5)
                                            # @cursor_select        = TT;;Cursor.get_id( ;select )
                                            @cursor_select_add    = UI.create_cursor(cursor_select_curve_plus_path, 9, 5)
                                            # @cursor_select_add    = TT;;Cursor.get_id( ;select_add )
                                            @cursor_select_remove = UI.create_cursor(cursor_select_curve_minus_path, 9, 5)
                                            # @cursor_select_remove = TT;;Cursor.get_id( ;select_remove )
                                      		@cursor_select_toggle = UI.create_cursor(cursor_select_curve_plus_minus_path, 9, 5)
                                            # @cursor_select_toggle = TT;;Cursor.get_id( ;select_toggle )
                                            @ctrl   = false
                                            @shift  = false
                                      (I'm not good in Ruby, sorry)
                                      Hope this helps.
                                      Renaud
                                      • 2 / 2
