    [Plugin] Select Curve
    37 Posts 16 Posters 53.3k Views 16 Watching
    • ken28875K
      ken28875
      Hi Thomas,
      I was working on this project Friday night and spent a lot of time selecting each of the edges of the circle. Then I took a break by visiting Sketchucation. And guess what, I saw your Select Curve plugin thread. I was like, wow just what I needed! Thomas you're the man. ๐Ÿ‘
      I was mentioning to you about the possibility of selecting the hidden edges of the curve. I did actually find a plugin that does the trick. I don't know who wrote it, but it's called "Connected edges by Angle" and it works just fine.
      I also find out that you posted a bunch of new awesome plugins this past few weeks. Thank you so much for taking time to write them. I will feed you some cookies.
      Anyway, here are some images of what I was working on that needed your Select Curve last night.
      All the Best,
      _KN
      http://i593.photobucket.com/albums/tt12/ken28875/Art of Sketchhup - Sci-Fi/Starship_WIP_04c.jpg
      http://i593.photobucket.com/albums/tt12/ken28875/Art of Sketchhup - Sci-Fi/vray_EVE_test_04a.jpg
      Follow Your Dreams.
        Oh yea - that is a feature in Selection Toys. ๐Ÿ˜„
          @watkins said:
          Dear Thomas,
          Can your script be modified to both find a 'circle' and to 'recreate' that 'circle' so that it has the correct entity assignment (not a curve, nor an arc, but a circle).
          Kind regards,
          Bob
          Dear Bob,
          Although it won't change the Entity description from 'Curve' to 'Circle', Weld.rb will at least make it select like a circle. Would that help?
            Ken - what kind of machine are you creating there?? ๐Ÿ˜ฒ ๐Ÿ˜ฎ
            • ken28875K
              ken28875
              Hi Thomas,
              I am working on a time traveling machine. I will go back 15 years ago when I was an architecture student and will create Sketchup so I can do crazy stuff instead of using pencil, markers, spray paints, and tracing paper. ๐Ÿ˜‰
              Just kidding. ๐Ÿ˜„
              It is for a contest I am doing that is due next month. http://news.deviantart.com/article/128272/
              You can see some of the WIP here: http://forums.sketchucation.com/viewtopic.php?f=81&t=27030
              Have a nice week!
              _KN
              Follow Your Dreams.
                Ooh, sweet prices. I don't really pay attention any more what goes on at dA...
                • W
                  watkins
                  Dear David,
                  My usual method is as follows:
                  a) Find the centre of the broken circle, and mark with a cpoint.
                  b) Using the cpoint, draw a circle over the broken circle and delete any unwanted face so formed.
                  c) Use move+copy to move copies of the reconstructed circle entity up/down to recreate other broken circles.
                  For point c), think of a simple circular flange and copying the top outer edge to the bottom outer edge (same diameter)using move+copy.
                  The above method reconstructs the circle and re-assigns the entity 'circle' to the feature, but it takes time and one has to be careful to delete unwanted faces.
                  Yes, I could use weld, but the resulting feature has the assignment 'curve' rather than circle, which excludes the use of 'point at centre', which I use frequently for alignment. Chris Fullmer's Arc Centrepoint Finder has helped enormously, but it would be nice to revolve a shape and have circles formed. Thank you for considering my request.
                  Kind regards,
                  Bob
                    So simply drawing an arc or circle over an broken acr/circle mends it? hmmm
                    I already have the code to find the centre of exploded curves...
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=30506&p=267835&hilit=[Plugin]#p267835
                    • winoooW
                      winooo
                      Awesome,thx
                      www.mffw.blogspot.com
                      • H
                        horizon
                        I have managed to install your select curve on my laptop running xp but it will not load on my desktop running win 7... i wonder if there is an issue with it being a 64 bit machine?
                          64bit is no issue. I run 64bit Win7.
                          Do you get any errors or anything?
                          • O
                            Orthogon
                            Excellent, works cleanly. But wondering why it isn't added to the right-click context menu, where one usually looks for such things -?
                              Mythos
                              Thank you very much for this plugin. I like a lot! I want to propose a little improvement: Would it be possible to let the user even click on a face to automatically select all edges by this tool?
                                Although the "improvement" might be possible, since you'd already have the Select tool active, why not just double click on the face? That would select all of the bounding edges of the face without the added step of activating a plugin.
                                  Mythos
                                  Certainly you are right, but then you have to press SHIFT wait a second (to avoid tripple clicking) and then you have to click again to deselect the face (since you only want the edges be selected). It would be much more convenient to have a curve-only selection tool that even can select the edges of a clicked face.
                                  • cottyC
                                    cotty
                                    A quick way for this: select outer edges (Chris Fullmer) with a shortcut assigned
                                    my SketchUp gallery
                                      I use Selection Toys to quickly filter out entity types. I have Edges on Ctrl+1 and Faces on Ctrl+2, Groups and Components on Ctrl+3 and Ctrl+4.
                                      Then I have Ctrl+Shift+n to deselect. Those shortcuts are easily accessible to my left hand which is always on the keyboard while I model. Quite flexible setup.
                                        Mythos
                                        Nice, I change my hotkeys to use this setup too. But I think it would be very intuitive to have the normal select operation (which selects the face first) and a curve-based select operation (which forcly grabs the edges even if applied on faces). Since the "Select Curve" plugin currently doesn't operate at all on faces it would be just a nice addition that makes the "Select Curve" tool a little bit more powerful.
                                        • IltisI
                                          Iltis
                                          Hello @thomthom, thank you very much for this very usefull plugin.
                                          Is there a way to add a modified cursor? (I can draw it if you tell me the specifications.)
                                          • K
                                            KropocLeckor
                                            Hello, thomthom. I used Select Curve mainly on SU2015 and 2016 before I migrated to 2019. I use SelectCurve with a shortcut (Shift+C). But in 2019, when I pressed it, other tool pallets will pop up. Never SelectCurve. Changing Shortcut doesn't change anything. Same tool pallets still pop up. I remove/uninstall that particular plugin. And press again..another tool pallets will pop up. Why this happening? ๐Ÿ˜•
                                            Select Curve
                                            Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                                            Imgur (imgur.com)
                                            Thank you
                                            • 2 / 2
