    [Plugin] Select Curve
    37 Posts 16 Posters 53.3k Views 16 Watching
      Ooh, sweet prices. I don't really pay attention any more what goes on at dA...
      • W
        watkins
        Dear David,
        My usual method is as follows:
        a) Find the centre of the broken circle, and mark with a cpoint.
        b) Using the cpoint, draw a circle over the broken circle and delete any unwanted face so formed.
        c) Use move+copy to move copies of the reconstructed circle entity up/down to recreate other broken circles.
        For point c), think of a simple circular flange and copying the top outer edge to the bottom outer edge (same diameter)using move+copy.
        The above method reconstructs the circle and re-assigns the entity 'circle' to the feature, but it takes time and one has to be careful to delete unwanted faces.
        Yes, I could use weld, but the resulting feature has the assignment 'curve' rather than circle, which excludes the use of 'point at centre', which I use frequently for alignment. Chris Fullmer's Arc Centrepoint Finder has helped enormously, but it would be nice to revolve a shape and have circles formed. Thank you for considering my request.
        Kind regards,
        Bob
          So simply drawing an arc or circle over an broken acr/circle mends it? hmmm
          I already have the code to find the centre of exploded curves...
          http://forums.sketchucation.com/viewtopic.php?f=323&t=30506&p=267835&hilit=[Plugin]#p267835
          • winoooW
            winooo
            Awesome,thx
            www.mffw.blogspot.com
            • H
              horizon
              I have managed to install your select curve on my laptop running xp but it will not load on my desktop running win 7... i wonder if there is an issue with it being a 64 bit machine?
                64bit is no issue. I run 64bit Win7.
                Do you get any errors or anything?
                • O
                  Orthogon
                  Excellent, works cleanly. But wondering why it isn't added to the right-click context menu, where one usually looks for such things -?
                    Mythos
                    Thank you very much for this plugin. I like a lot! I want to propose a little improvement: Would it be possible to let the user even click on a face to automatically select all edges by this tool?
                      Although the "improvement" might be possible, since you'd already have the Select tool active, why not just double click on the face? That would select all of the bounding edges of the face without the added step of activating a plugin.
                        Mythos
                        Certainly you are right, but then you have to press SHIFT wait a second (to avoid tripple clicking) and then you have to click again to deselect the face (since you only want the edges be selected). It would be much more convenient to have a curve-only selection tool that even can select the edges of a clicked face.
                        • cottyC
                          cotty
                          A quick way for this: select outer edges (Chris Fullmer) with a shortcut assigned
                          my SketchUp gallery
                            I use Selection Toys to quickly filter out entity types. I have Edges on Ctrl+1 and Faces on Ctrl+2, Groups and Components on Ctrl+3 and Ctrl+4.
                            Then I have Ctrl+Shift+n to deselect. Those shortcuts are easily accessible to my left hand which is always on the keyboard while I model. Quite flexible setup.
                              Mythos
                              Nice, I change my hotkeys to use this setup too. But I think it would be very intuitive to have the normal select operation (which selects the face first) and a curve-based select operation (which forcly grabs the edges even if applied on faces). Since the "Select Curve" plugin currently doesn't operate at all on faces it would be just a nice addition that makes the "Select Curve" tool a little bit more powerful.
                              • IltisI
                                Iltis
                                Hello @thomthom, thank you very much for this very usefull plugin.
                                Is there a way to add a modified cursor? (I can draw it if you tell me the specifications.)
                                • K
                                  KropocLeckor
                                  Hello, thomthom. I used Select Curve mainly on SU2015 and 2016 before I migrated to 2019. I use SelectCurve with a shortcut (Shift+C). But in 2019, when I pressed it, other tool pallets will pop up. Never SelectCurve. Changing Shortcut doesn't change anything. Same tool pallets still pop up. I remove/uninstall that particular plugin. And press again..another tool pallets will pop up. Why this happening? 😕
                                  Select Curve
                                  Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                                  Imgur (imgur.com)
                                  Thank you
                                  • IltisI
                                    Iltis
                                    Hi @thomthom and folks,
                                    I just managed to insert custom cursors to this usefull plugin.
                                    Attached are the .png files.
                                    The images are in the same folder than "core.rb"
                                    And this is the code :
                                    def initialize(settings)
                                          @settings = settings
                                    		folder_path = File.dirname(__FILE__)
                                    		cursor_name = 'cursor_select_curve.png'
                                    		cursor_select_curve_path = File.join(folder_path, cursor_name)
                                    	   @result = File.file?(cursor_select_curve_path)
                                    	   unless @result
                                    		  msg = "Can't find the 'cursor icon' path"
                                    		  UI.messagebox(msg, MB_OK)
                                    		  return
                                    		cursor_name = 'cursor_select_curve_plus.png'
                                    		cursor_select_curve_plus_path = File.join(folder_path, cursor_name)
                                    	   @result = File.file?(cursor_select_curve_plus_path)
                                    	   unless @result
                                    		  return
                                    		cursor_name = 'cursor_select_curve_minus.png'
                                    		cursor_select_curve_minus_path = File.join(folder_path, cursor_name)
                                    	   @result = File.file?(cursor_select_curve_minus_path)
                                    	   unless @result
                                    		  return
                                    		cursor_name = 'cursor_select_curve_plus_minus.png'
                                    		cursor_select_curve_plus_minus_path = File.join(folder_path, cursor_name)
                                    	   @result = File.file?(cursor_select_curve_plus_minus_path)
                                    	   unless @result
                                    		  return
                                    		@cursor_select        = UI.create_cursor(cursor_select_curve_path, 9, 5)
                                          # @cursor_select        = TT;;Cursor.get_id( ;select )
                                          @cursor_select_add    = UI.create_cursor(cursor_select_curve_plus_path, 9, 5)
                                          # @cursor_select_add    = TT;;Cursor.get_id( ;select_add )
                                          @cursor_select_remove = UI.create_cursor(cursor_select_curve_minus_path, 9, 5)
                                          # @cursor_select_remove = TT;;Cursor.get_id( ;select_remove )
                                    		@cursor_select_toggle = UI.create_cursor(cursor_select_curve_plus_minus_path, 9, 5)
                                          # @cursor_select_toggle = TT;;Cursor.get_id( ;select_toggle )
                                          @ctrl   = false
                                          @shift  = false
                                    (I'm not good in Ruby, sorry)
                                    Hope this helps.
                                    Renaud
                                    • 2 / 2
