    Batch Render PRoblem
    renderpluginsextensions
    4 Posts 3 Posters 1.6k Views 3 Watching
    • C
      clarko74
      Hello all,
      I'm new to the forum, although I've been using sketchup for a while I've only been using Vfsu for a few weeks (still using the demo, version 1.48.89).
      I have been trying to do a batch render, which Vray is doing as I can see it rendering each frame in the image buffer, however no matter what I try I cannot get it to save the frames as separate image files, it just overwrites the same file each time (I have opened the image file while it is rendering and seen that it changes as each frame is rendered).
      I have done a few searches to try to resolve this and found a few guides to setting up rendering an animation, these refer to making sure the the "batch render" option is on in global switches, I have looked for this but there is no such option available (see screen shot below), where is this?. When referring to saving the images the guides I have found also refer to specifying the folder where the images are to be saved, I can only specify the actual filename within the folder, is this something to do with it?
      http://i691.photobucket.com/albums/vv276/clarko74/mda/screenshot-01.jpg
      I would be grateful of any assistance in sorting this out as I'm currently trailing Vfsu for my company and being able to render a series of images over night is important to us.
      Thanks in advance,
      Adrian
      • thomthomT
        This sounds like something you should report to ASGVis.
        • C
          clarko74
          I've done that. We'll see what they say...
          • A
            alucidwake
            this just happened to me as well. the solution is to click 'include frame number' under the output tab
