    Painting a material in a 3D view
    17 Posts 8 Posters 1.7k Views 8 Watching
    • Al HartA Offline
      Al Hart
      Has anyone every created, or wanted, this feature:
      The ability to export a face with texture into a paint program, paint on the existing texture, and then reload it back into SketchUp.
      1. Select a face in a 3D view.
      1. Export the face, with its existing texture, in 3D view, into a paint program and paint on it.
      1. Resave it, and reload into SketchUp as a new texture, positioned properly on the face:
      In this sample, the face was painted from the already shaded texture in SketchUp. With a little work, you could paint on the original material instead, so that, when reloaded it could be loaded into SketchUp and reshaded.
      Has anyone created a ruby to do this already?
      Is anyone doing this already by hand?
      Would this be a useful feature?
      (If I make it, I would probably add it to NprTools)
      It would be relatively easy to do this for a single, flat, face. It would be much harder to do it for a curved surface, as in this example where the blue painted part would have to be placed on several surfaces and on curved surfaces.
      Al
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
        From I have seen in the SU 8 Demo, this is made directly from Google Earth to Photomatch 😉
        So if you can put your paintings in Google Eath that will work 😄
          Wouldn't this pretty much be similar to Make Unique Texture and then Edit Texture Image... ?
          As long as you're talking about single flat surfaces.
          • N Offline
            notareal
            Did I misunderstood something, but is this basically the same as 'right click on model' > 'Texture' > 'Edit Texture Image...'? (if you have only colour, you first need to use 'Make Unique Texture'.
            For later option. Take a look on this video http://www.youtube.com/v/XUfNLCMnWz4&feature=related
            If someone implements a "paint through" feature inside SU, my bet is that it will be a great hit.
            edit: @Thomas you beat me. 🤣
            • soloS Offline
              solo
              What I'd love (read pay money for) is the ability to paint on textures, use my tablet and paint away, curves and all, then be able to blend over with other textures using some sort of a blending slider.
              So...who's gonna make it? 💚
              http://www.solos-art.com
                richcat
                Yes guys you are right you can already do this with a face (edit or flat surface)in Sketchup. 😳
                As suggested wouldn't it be great though if we had a 3d paint or paint through in sketchup, internal or external. See comment in Al's email on the blue lines above. I have been trying various programs over the years like Argile2 etc. I was just asking him if he knew of such a program that would work direct with sketchup similar to NPR tools.
                Apologies to Al 😳 as my rambling mixedup pm email this morning which has confused the matter, on painting faces in sketchup.
                • tbdT Offline
                  tbd
                  solo: watch the space. you are on the beta list anyway 😉
                  SketchUp Ruby Consultant | Podium 1.x developer
                  http://plugins.ro
                  • soloS Offline
                    solo
                    My day has been made!!!
                      richcat
                      Ahh the plot thickens 😄
                      • X Offline
                        xrok1
                        have you tried 3Dcoat ?
                        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        • soloS Offline
                          solo
                          Yup and I love it, so imagine that in SU, however have you seen Mari 3D painting?
                          • X Offline
                            xrok1
                            Mari looks impressive. to have these abilities in SU would be another milestone like SDS, curviloft, vertex tools, JPP... just to name a few 😄
                            • soloS Offline
                              solo
                              I can only dream.
                              However then we may get into the problem of Rendering as I would think that such abilities would create millions of unique textures.
                              • Al HartA Offline
                                Al Hart
                                Its a minor difference, but I was planning to "distort" the texture as I loaded it into he editor to match the current 3D view, and then "un-distort" the texture as I put it back.
                                Then, If you added a circle in the 3D view to the texture, it would remain a circle in the same view in SketchUp.
                                Or if you added patterned strokes, they would retain the same pattern.
                                But it sounds more like Richcat was hoping to draw in paint, on the 3D image, and then apply the changes to each sub-surface (creating a new texture for each sub-surface)
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  @solo said:
                                  I can only dream.
                                  One "trick" a supplier of textured objects uses is to create a single texture with the 1,000's of small sub-textures in it, and then position the textures cleverly to the individual faces. This could easily be done here as well. (You just need one texture - the painted image - and then map it to the original faces so that it looks the same in the one particular view.)
                                  Similarly, it the object already has a texture, wrapped around various surfaces, then you can distort the 3D painted image onto the original texture. With a little work you could superimpose only the changed pixels onto the original texture.
                                  Does PhotoMatch, or 3D street view, or whatever, already wrap an image onto surfaces, or multiple faces to keep the same appearance?
                                  Al Hart
                                    Is that I said second post 😄
                                    See video from 0. 45 minutes and following 😉
                                    • Al HartA Offline
                                      Al Hart
                                      I'll have to look a little closer at the video. (I just looked at it, but I might have to watch harder.)
                                      I was quite impressed by the Street View stuff at the Base Camp, but as I remember it, he had to apply the street view texture separately to each face on the building he had created. And he had to stretch and dirstort the image to match the face - so it wasn't an automatic process (or am I missing something
                                      Also, when you use PhotoMatch for a texture, does it then get shaded? If so I will need to save an unshaded image from SketchUp. (I believe I can do this by turning the sun on for shading, setting Light intensity to 0 and Dark intensity to 100)
                                      Al Hart
