    Painting a material in a 3D view
    17 Posts 8 Posters 1.7k Views 8 Watching
    • tbdT Offline
      tbd
      solo: watch the space. you are on the beta list anyway 😉
      http://plugins.ro
      • soloS Offline
        My day has been made!!!
          richcat
          Ahh the plot thickens 😄
          • X Offline
            xrok1
            @solo said:
            What I'd love (read pay money for) is the ability to paint on textures, use my tablet and paint away, curves and all, then be able to blend over with other textures using some sort of a blending slider.
            So...who's gonna make it? 💚
            have you tried 3Dcoat ?
            • soloS Offline
              Yup and I love it, so imagine that in SU, however have you seen Mari 3D painting?
              • X Offline
                xrok1
                Mari looks impressive. to have these abilities in SU would be another milestone like SDS, curviloft, vertex tools, JPP... just to name a few 😄
                • soloS Offline
                  I can only dream.
                  However then we may get into the problem of Rendering as I would think that such abilities would create millions of unique textures.
                  • Al HartA Offline
                    Al Hart
                    Its a minor difference, but I was planning to "distort" the texture as I loaded it into he editor to match the current 3D view, and then "un-distort" the texture as I put it back.
                    Then, If you added a circle in the 3D view to the texture, it would remain a circle in the same view in SketchUp.
                    Or if you added patterned strokes, they would retain the same pattern.
                    But it sounds more like Richcat was hoping to draw in paint, on the 3D image, and then apply the changes to each sub-surface (creating a new texture for each sub-surface)
                    @thomthom said:
                    @al hart said:
                    1. Export the face, with its existing texture, in 3D view, into a paint program and paint on it.
                    Wouldn't this pretty much be similar to Make Unique Texture and then Edit Texture Image... ?
                    As long as you're talking about single flat surfaces.
                    Al Hart
                    IRender nXt from Render Plus
                    • Al HartA Offline
                      Al Hart
                      @solo said:
                      I can only dream.
                      One "trick" a supplier of textured objects uses is to create a single texture with the 1,000's of small sub-textures in it, and then position the textures cleverly to the individual faces. This could easily be done here as well. (You just need one texture - the painted image - and then map it to the original faces so that it looks the same in the one particular view.)
                      Similarly, it the object already has a texture, wrapped around various surfaces, then you can distort the 3D painted image onto the original texture. With a little work you could superimpose only the changed pixels onto the original texture.
                      Does PhotoMatch, or 3D street view, or whatever, already wrap an image onto surfaces, or multiple faces to keep the same appearance?
                      Al Hart
                        Is that I said second post 😄
                        See video from 0. 45 minutes and following 😉
                        • Al HartA Offline
                          Al Hart
                          I'll have to look a little closer at the video. (I just looked at it, but I might have to watch harder.)
                          I was quite impressed by the Street View stuff at the Base Camp, but as I remember it, he had to apply the street view texture separately to each face on the building he had created. And he had to stretch and dirstort the image to match the face - so it wasn't an automatic process (or am I missing something
                          Also, when you use PhotoMatch for a texture, does it then get shaded? If so I will need to save an unshaded image from SketchUp. (I believe I can do this by turning the sun on for shading, setting Light intensity to 0 and Dark intensity to 100)
                          Al Hart
