    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 131.0k Views 42 Watching
    • tt_suT Offline
      tt_su
      @ntxdave said:
      Compression setting - What does it accomplish? What is recommendation?
      That applies only to JPEG. Higher value is less compression if I remember correctly.
      @ntxdave said:
      Antialias setting - Default is No and I have to set it to Yes each time. Any recommendation?
      Hmm.. that might be a bug. I actually never use it as I think the AA is too poor. I prefer exporting without AA in a larger size, like double, and resize down in PhotoShop. It's even faster as AA is so slow.
      • ntxdaveN Offline
        ntxdave
        That is good to know. Thanks. I will ignore that setting since I generate PNG files.
        I have had a problem a few times when I had to create the image multiple times because of sizing issues. Sometimes I had to increase the width setting. I use AA almost every time (just a habit in creating graphics). I will have to try a couple without the AA and then compare them. I am using the tool to build a catalog/brochure/guide of the components I have built for the company I am doing the work for. I really like the capability this tool adds.
        Press F1...thank me later
        • E Offline
          Einstein
          In SU17 it exports entire model instead of just active entities 😞
          • V Offline
            vidy
            You can have it work with SU 2015, that's it, so far no update for latest sketchup from thom2.
            Regards,
            VD
            still so much to learn..
            • jenujacobJ Offline
              jenujacob
              hi! since this has not been updated to work with the latest version of sketchup 2019, is there any other plugin that does a similar job?
                jman0war
                Old thread that i just came across.
                I have a need to export PNG with Transparent background.
                Found this goodie, but i get an error at load now (SU 2014).
                  Ancient version of SketchUp. You probably need an ancient version of TT_Lib2.
                    rv1974
                    Wow 32bit! when 64bit was introduced?
                    • 6
                    • 7
                    • 8
                    • 8 / 8
