    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 143.9k Views 42 Watching
      The brush exported just fine for me. Are you remembering to append .png to the file name?
      • ntxdaveN
        ntxdave
        [attachment=0:2q8ziqup]<!-- ia0 -->brush.png<!-- ia0 -->[/attachment:2q8ziqup]
        I just tried that with both of the files I had attached and yes, it worked. πŸ‘
        Interesting that some times it worked without entering the .png and some times it did not. I will start over and see if I now get all of the images
        BTW: Can you address these two settings:
        Compression setting - What does it accomplish? What is recommendation?
        Antialias setting - Default is No and I have to set it to Yes each time. Any recommendation?
        Press F1...thank me later
        • tt_suT
          tt_su
          That applies only to JPEG. Higher value is less compression if I remember correctly.
          Hmm.. that might be a bug. I actually never use it as I think the AA is too poor. I prefer exporting without AA in a larger size, like double, and resize down in PhotoShop. It's even faster as AA is so slow.
          • ntxdaveN
            ntxdave
            That is good to know. Thanks. I will ignore that setting since I generate PNG files.
            I have had a problem a few times when I had to create the image multiple times because of sizing issues. Sometimes I had to increase the width setting. I use AA almost every time (just a habit in creating graphics). I will have to try a couple without the AA and then compare them. I am using the tool to build a catalog/brochure/guide of the components I have built for the company I am doing the work for. I really like the capability this tool adds.
            • E
              Einstein
              In SU17 it exports entire model instead of just active entities 😞
              • V
                vidy
                You can have it work with SU 2015, that's it, so far no update for latest sketchup from thom2.
                Regards,
                VD
                still so much to learn..
                • jenujacobJ
                  jenujacob
                  hi! since this has not been updated to work with the latest version of sketchup 2019, is there any other plugin that does a similar job?
                    jman0war
                    Old thread that i just came across.
                    I have a need to export PNG with Transparent background.
                    Found this goodie, but i get an error at load now (SU 2014).
                      Ancient version of SketchUp. You probably need an ancient version of TT_Lib2.
                        rv1974
                        Wow 32bit! when 64bit was introduced?
                        • 8 / 8
