How to add entities to a nested group?
I want to have an Entities object which contains a face and its edges, and I want to group these entities, then add them to a different existing group which is nested 2 levels deep from Sketchup.active_model.entities. I tried this:
# I already have the face (face), and the nested group (level2group) I want to add it to... ents = face.edges() ents.push(face) faceGroup = level2group.entities().add_group(ents)This doesn't work... faceGroup ends up without a parent, it seems. I attached a picture of what it looks like in the Outliner.
also... the groups are locked, but should that make a difference? I tried unlocking them first and got the same result.
This face, are you creating it at some earlier point in your code?
You can't move entities between contexts.
However, if you have two groups within the same context you can add both of these to a new group.
Then you can explode one or both of these groups inside this new group - then you have a group containing both sets of entities etc...
If you first get all of the first 'parent' group's details - [layer/material/name/properties/description/attributes] and then 'transfer them to this new group then you have effectively 'moved' the face-group [or its entities] into it, as for all intents and purposes it's become the same thing... [There's another recent thread about this...]
No, it's an existing face in the model.
For example, let's assume you have a group in the model 'group1' and a 'face' in the same 'context'...
You use:
grp=model.active_entities.add_group(group1, face)now get group1 details to transfer - e.g.
name=group1.namegroup1.explodenow rename/change details of grp to match group1 - e.g.
grp.name=namegroup1=grp
TIG, can you define "context?" Do you mean parent group?
I want to nest this "faceGroup" 2 levels deep from model.entities... Does that mean I first have to do your trick to put it in level1group, then again to put it in level2group? This seems ridiculous! What if I wanted to nest faceGroup arbitrarily deep in a dynamic tree of groups? I'd have to write a recursive algorithm that copies all the group information over and over and over... All I'm really doing is changing faceGroup's parent group, right?
Also... the face entities are both under model.entities, it's just that level2group is under level1group, which is under model.entities...
Also... the face entities are both under model.entities, it's just that level2group is under level1group, which is under model.entities...The 'context' is the set of entities that the entity is in e.g. model.entities or group.entities or definition.entities - that is it's the entities of the parent of the entity!
To add the faces 'face1' and 'face2' to a new group [group1] inside an existing group [group] that is in the same 'context' as the faces you first get that context...
context=group.parent
entities=context.entities
group1=entities.add_group(face1,face2)
group_temp=entities.add_group(group1,group)get all 'group' properties here...
e.g. mat=group.material, layer=group.layer etc
group.explode ### the entities are now back inside a group with another group next to them [group1]...
group=group_temp ### group now refers back to the new containeradd the original group's properties to its new 'clone' - it's name is also referred to as 'group'...
e.g. group.material=mat, group.layer=layer etc
This is only working for me to get the faceGroup nested one level deep from model.entities. After that, I get weird results. There exists rootGroup (under model.entities), which contains groupGroup, and I have a face, which should be grouped with its edges and placed inside of groupGroup:
` # Make an array of the entities:
faceEntities = face.edges()
faceEntities.push(face)# Get faceGroup inside of rootGroup: faceGroup = @model.entities().add_group(faceEntities) newRootGroup = @model.entities().add_group(rootGroup, faceGroup) # Copy properties of rootGroup to newRootGroup here... rootGroup.explode() rootGroup = newRootGroup # Things seem to work up until here... # Now nest it one level deeper: newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup) # Copy properties of groupGroup to newGroupGroup here... groupGroup.explode() groupGroup = newGroupGroup`This line:
newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)seems to copy my face/edges geometry and creates a new group... also, this crashes the program when I try to explode groupGroup (last line). What's going on?After creating faceGroup under model.entities:
Right before I explode groupGroup:
You cannot 'move' entities across 'contexts' when combining them into a new group.
That's what I tried to explain... how you need to find the common context level for the entities you are combining [even if that's back as the 'model.entities'], then combine the objects [or their parents, or copies of their parents in the same context - e.g. group.copy] into this new group... and then explode the sub-bits as needed...
Cross-threading entities is a sure recipe for a Bugsplat...
Also usemodel.active_entitiesIF you might be working initially NOT inmodel.entities- they can be the same if you are working 'in' the model... but 'entities' might refer to perhapsgroup.entitiesordefinition.entitiesif you were to start in an 'edit' that is not the 'model'.
Note thatfaces[0]parent.entitieswill match the 'faces' entities context more safely...You have a group and faces that you want to transfer into the group.
Make a new_group containing the group AND the faces.
Now get all of the properties of the group - name/description/layer/material etc etc
Repeat those on the new_group.
Explode the group inside the new_group.
For all intents and purposes 'new_group' IS 'group' AND it now contains the faces and its previous geometry/entities at the same context level inside it... -
For all intents and purposes 'new_group' IS 'group' AND it now contains the faces and its previous geometry/entities at the same context level inside it...I'm sorry, but isn't that what I'm doing? I practically copied your code... Where am I "moving entities across contexts" ?????
faceGroup and groupGroup are in rootGroup - i.e., "same context." Then I create a newGroupGroup, containing faceGroup and groupGroup. I transfer properties of groupGroup to newGroupGroup, then explode groupGroup, and set groupGroup = newGroupGroup. Am I crazy or is this exactly what you're describing?
Also, I don't have multiple faces. I have a single face, and I want these entities grouped together, then placed under model.entities -> rootGroup -> groupGroup.
EDIT: "newRootGroup" -> "newGroupGroup" in 2nd paragraph...
I must assume
faceEntitiesis in the same context as the rest.
But innewGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)
where didgroupGroupsuddenly come from ? It's not referred to in your example code...
and IT must be inside therootGroup.entities- BUT where'd it come from...
THEN you explode this probbaly non-existent thing == Bugsplat ???You seem to have overcomplicated it...
Also simply saying group2=group1 is changing a reference - it doesn't transfer 'properties' or 'attributes' - so you need to get the original group2 name and give that to the group2, and the same with layers, materials etc etc...
As I said
tgroup=ents.add_group(extggroup,facebits)
'remember' extggroup details first, then
extggroup.explode
you have now got the entities that were in 'extggroup' AND 'facebits' inside the same group...
Now re-refer to tgroup as extggroup and add the 'remembered' extggroup details to []what is now 'called' extggroup ... -
@tig said:
I must assume
THEN you explode this probbaly non-existent thing == Bugsplat ???faceEntities is under model.entities. rootGroup is under model.entities. groupGroup is already under rootGroup (look at the screenshots!). In fact, I created groupGroup with rootGroup.entities.add_group() (I'm 100% sure that groupGroup is correct; I can even find it by searching rootGroup.entities.each())
How?
I AM doing this. Look at the comments in the example code. The only purpose of
groupGroup = newGroupGroupis to keep my variable names, since in the real code these are instance variables.@tig said:
extggroup.explode
Now re-refer to tgroup as extggroup and add the 'remembered' extggroup details to []what is now 'called' extggroup ...Why do I have to store these properties? Consider this:
` newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)Copy properties of groupGroup to newGroupGroup here...
groupGroup = newGroupGroup`I don't see anything wrong with copying the properties directly before I explode groupGroup. The properties are going from groupGroup to newGroupGroup, so at one point they will have identical properties. Then I explode groupGroup. Seems okay to me...
Last things first...
Assuming the next two objects mentioned are in the same 'context'...
A group variable 'group1' is named "mygroup1", it's onlayer"XXXX" and hasmaterial"red" etc. This is the group we are adding to
A group variable 'group2' is named "mygroup2", it's onlayer"AAAA" and hasmaterial"banana" etc. This is the group we want to add.
You add a temporary group thus:
newgroup=group1.parent.entities.add_group(group1,group2)
At this point variable 'newgroup' has name="", layer=nil and material=nil etc.
When you explode 'group1' all of it properties and attributes vanish with it [properties reside with the object NOT its variable]... UNLESS you save the properties/attributes BEFORE you do the explode thus:
name=group1.name layer=group1.layer mat=group1.material
etc
NOW you can explode group1, change its referring variable to the temporary group...
group1=newgroup group1.name=name group1.layer=layer group1.material=mat
etc
NOW for all intents and purposes the group is still group1 [its 'id' has changed but nothing else].
So you end up with a group variable 'group1' named etc exactly as before containing the same entities PLUS 'group2'...
You can also explode group2 if desired...You say
faceEntitiesis undermodel.entities.rootGroupis undermodel.entities. groupGroup is already underrootGroup...
BUTnewGroupGroup = rootGroup.entities.add_group(groupGroup, faceGroup)[note the removed()after entities - not correct !!!] will add a group to rootGroup's entities, and remember that at this point in your coderootGroupis now a pointer to what wasnewRootGroup... which you have just made inside@model.entitiesfrom the originalrootGroupand [ruby:1upcmdm6]faceGroup[/ruby:1upcmdm6].
You are therefore adding two things into this [ruby:1upcmdm6]newGroupGroup[/ruby:1upcmdm6] ... [ruby:1upcmdm6]faceGroup[/ruby:1upcmdm6] which IS in there as you have just added it AND the mysterious [ruby:1upcmdm6]groupGroup[/ruby:1upcmdm6] BUTnewRootGroup[now referred to arootGroup] was made from [ruby:1upcmdm6]faceGroup[/ruby:1upcmdm6] ANDrootGroupwhich you then exploded after it was added - so unless [ruby:1upcmdm6]groupGroup[/ruby:1upcmdm6] was already inside that and is therefore now inside the now calledrootGroupafter the explosion, AND you had previously referred explicitly to it BEFORE all of this - which is NOT shown in any of your code
- then it WILL fail - if you have made a reference to an 'object' that seems to have appeared from nowhere and therefore ==nil.
Do you have a handle to this 'object' set up before this code snippet ?
You are perhaps onfusing the groups' references [variables] and their actual names [which appear in the Outliner]... So it may be named 'groupGroup' but is there a variable called 'groupGroup' that is pointing at it ?? There's nothing in your code to show it...
Try tidyinh your syntax [remove unneeded () etc] and check that everything is properly 'referred to' by variables -
which can share the objetc's names but need to be called explicitly.
Also note that making a new group [unlike making a copy of it] defaults all of its properties/attributes - and you have to transfer them to its 'clone'...
TIG, I really appreciate your help, but I still can't see that I'm doing anything wrong.
I've made a small example script that emulates my bug. Could you take a look please please?
Try this...
# Testing group nesting ### with TIG edits ### model = Sketchup.active_model entities = model.active_entities ### NOTE; 'active_' pts = [] pts[0] = [0, 0, 0] pts[1] = [100, 0, 0] pts[2] = [100, 100, 0] pts[3] = [0, 100, 0] face = entities.add_face(pts) faceGroup = entities.add_group(face) faceGroup.name = "faceGroup" ### A GROUP REFERRED TO AS 'faceGroup', NAMED 'faceGroup'. ### IT CONTAINS THE FACE AND ITS EDGES - THEY ARE COPIED IT THEY ARE ### STILL NEEDED IN THE ORIGINAL ENTITIES... rootGroup = entities.add_group() rootGroup.name = "rootGroup" ### A GROUP REFERRED TO AS 'rootGroup', NAMED 'rootGroup'. newGroup = rootGroup.entities.add_group(faceGroup) newGroup.name = rootGroup.name ### THERE'S NOW A GROUP REFERRED TO AS 'newGroup', BUT CALLED 'rootGroup' ### INSIDE IT IS A GROUP REFERRED/CALLED 'rootGroup' ### WHICH CONTAINS A GROUP REFERRED/NAMED 'faceGroup' ### WHICH CONTAINS THE 'face' ENTITIES... ### NOW DO WHAT YOU WANT... ### -
@tig said:
Try this...
Try what? I did all of this in my code! I also want to nest faceGroup one level deeper, into "groupGroup."
As I said, getting faceGroup inside of rootGroup isn't a problem. It works using your trick. But I need it to go one level deeper, into groupGroup, and it's not working!!!
You stopped the code RIGHT BEFORE the point where I don't know what's wrong... And you took out the part with groupGroup, which is my entire problem!
Your code does this:
Please TIG or someone else, can you tell me specifically in my code, i.e. what line and WHY, am I doing wrong? I posted the example which reproduces my bug. What am I doing wrong? This bug has been stopping me for a week now... it's getting ridiculous!
This 'groupGroup' must be inside the same context as 'faceGroup'... OR...
You already have
rootGroup** IN model.entities
AND
face IN faceGroup IN newGroup [also named 'rootGroup'** BUT it is a different group] IN model.entitiesso simply use:
groupGroup=newGroup.entities.add_group(faceGroup)
groupGroup.name="groupGroup"face IN faceGroup IN groupGroup IN newGroup [named 'rootGroup'**] IN model.entities
OR you add another a group to model.entities
groupGroup=entities.add_group(newGroup)
groupGroup.name="rootGroup" ###***face IN faceGroup IN newGroup [named 'rootGroup'] IN groupGroup [named yet another 'rootGroup'*] IN model.entities
You just have to decide which groups contain which.
Naming groups with the same name is plain confusing - why do it ?
Give them each a unique reference and at the end name them appropriately... -
Okay, you're just confusing me now, and what you're describing doesn't work for my situation. groupGroup already exists, and rootGroup already exists. I'm only creating them again in my example so that it can stand alone. So doing anything like
groupGroup=newGroup.entities.add_group(faceGroup)isn't acceptable, because groupGroup is ALREADY THERE.Look TIG, can we get a bit simpler? Can you look quickly at test_group_bug.rb? I just simply don't understand why this line:
LINE 49:newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)
is breaking my code. As far as I can see, this is EXACTLY what you've told me to do. The contexts of groupGroup and faceGroup are identical (faceGroup.parent = rootGroup, and groupGroup.parent = rootGroup... I've checked).Moreover, the SAME CODE works several lines up, when I do the SAME THING, except in model.entities instead of in rootGroup. I'm very confused, and I need a straightforward answer. What EXACTLY is wrong about that line of code?
The 'groupGroup' group DOESN'T really exist... except that you have made an empty group [too early] with that reference.
Adding that empty group so early on into the mix and then trying to 'move' it into another group only confuses things.
IF you already have a non-empty group with that reference then it's OK... but if not only make it when you need it otherwise.If you still can't get your head around this then please post a simple before and after set of uniquely named objects with their hierarchy - e.g.
modelEntities=model.active_entitiesCONTAINING [at least] groupX [an existing group that isn't empty] and face [a face]
OR ANY OTHER entities set with common objects you are to 'group' ?
groupX > modelEntities
face > modelEntitiesWHICH BECOMES
faceGroup = modelEntities.add_group(face)face > faceGroup > modelEntities
THEN
group1 = modelEntities.add_group(faceGroup, groupX)face > faceGroup > group1 > modelEntities
groupX > group1 > modelEntitiesTHEN
group2 = group1.entities.add_group(faceGroup, groupX)face > faceGroup > group2 > group1 > modelEntities
groupX > group2 > group1 > modelEntitiesTHEN
group3 = group2.entities.add_group(groupX)face > faceGroup > group2 > group1 > modelEntities [STILL THE SAME AS BEFORE]
groupX > group3 > group2 > group1 > modelEntitiesTO SEPARATE THE ENTITIES INTO SEPARATE GROUPS ETC ETC...
YOU CAN GO ON AND ON...
This has no 'names' just references to groups etc - you can add those later...
IF you already have a non-empty group with that reference then it's OK... but if not only make it when you need it otherwise.In my real code, there is already a CPoint inside "groupGroup." If you think it's a problem that groupGroup is empty, then fine, I just tried adding a CPoint to groupGroup in my example script. Still broken.
Sir, my head is wrapped around this problem about 9 times already. I feel like you think I don't understand, but I do. I understand every word you have written, and I keep telling you, "I'm doing that, I'm doing that. Look at my code, look at my code."
I did this already. Look at my script!!! Look at my screenshots!!! I am creating rootGroup and groupGroup. That is my hierarchy.
I'm going to repeat my question again. What is wrong with line 49 of my previous example script? I COMPLETELY understand EVERYTHING you're telling me, and I believe I'm doing it, but it's still broken, and I don't see why!!!!!!!!!!
