    How to add entities to a nested group?
    32 Posts 4 Posters 2.7k Views 4 Watching
      @draftomatic said:
      TIG, can you define "context?" Do you mean parent group?
      I want to nest this "faceGroup" 2 levels deep from model.entities... Does that mean I first have to do your trick to put it in level1group, then again to put it in level2group? This seems ridiculous! What if I wanted to nest faceGroup arbitrarily deep in a dynamic tree of groups? I'd have to write a recursive algorithm that copies all the group information over and over and over... All I'm really doing is changing faceGroup's parent group, right?
      Also... the face entities are both under model.entities, it's just that level2group is under level1group, which is under model.entities...
      The 'context' is the set of entities that the entity is in e.g. model.entities or group.entities or definition.entities - that is it's the entities of the parent of the entity!
      To add the faces 'face1' and 'face2' to a new group [group1] inside an existing group [group] that is in the same 'context' as the faces you first get that context...
      context=group.parent
      entities=context.entities
      group1=entities.add_group(face1,face2)
      group_temp=entities.add_group(group1,group)
      get all 'group' properties here...
      e.g. mat=group.material, layer=group.layer etc
      group.explode ### the entities are now back inside a group with another group next to them [group1]...
      group=group_temp ### group now refers back to the new container
      add the original group's properties to its new 'clone' - it's name is also referred to as 'group'...
      e.g. group.material=mat, group.layer=layer etc
        draftomatic
        This is only working for me to get the faceGroup nested one level deep from model.entities. After that, I get weird results. There exists rootGroup (under model.entities), which contains groupGroup, and I have a face, which should be grouped with its edges and placed inside of groupGroup:
        ` # Make an array of the entities:
        faceEntities = face.edges()
        faceEntities.push(face)
          # Get faceGroup inside of rootGroup:
          faceGroup = @model.entities().add_group(faceEntities)
          newRootGroup = @model.entities().add_group(rootGroup, faceGroup)
          # Copy properties of rootGroup to newRootGroup here...
          rootGroup.explode()
          rootGroup = newRootGroup
          # Things seem to work up until here...
          # Now nest it one level deeper:
          newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)
          # Copy properties of groupGroup to newGroupGroup here...
          groupGroup.explode()
          groupGroup = newGroupGroup`
        This line: newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup) seems to copy my face/edges geometry and creates a new group... also, this crashes the program when I try to explode groupGroup (last line). What's going on?
        After creating faceGroup under model.entities:
        Right before I explode groupGroup:
          You cannot 'move' entities across 'contexts' when combining them into a new group.
          That's what I tried to explain... how you need to find the common context level for the entities you are combining [even if that's back as the ' model.entities'], then combine the objects [or their parents, or copies of their parents in the same context - e.g. group.copy] into this new group... and then explode the sub-bits as needed...
          Cross-threading entities is a sure recipe for a Bugsplat...
          Also use model.active_entitiesIF you might be working initially NOT in model.entities - they can be the same if you are working 'in' the model... but 'entities' might refer to perhaps group.entities or definition.entities if you were to start in an 'edit' that is not the 'model'.
          Note that faces[0]parent.entities will match the 'faces' entities context more safely...
          You have a group and faces that you want to transfer into the group.
          Make a new_group containing the group AND the faces.
          Now get all of the properties of the group - name/description/layer/material etc etc
          Repeat those on the new_group.
          Explode the group inside the new_group.
          For all intents and purposes 'new_group' IS 'group' AND it now contains the faces and its previous geometry/entities at the same context level inside it...
            draftomatic
            I'm sorry, but isn't that what I'm doing? I practically copied your code... Where am I "moving entities across contexts" ?????
            faceGroup and groupGroup are in rootGroup - i.e., "same context." Then I create a newGroupGroup, containing faceGroup and groupGroup. I transfer properties of groupGroup to newGroupGroup, then explode groupGroup, and set groupGroup = newGroupGroup. Am I crazy or is this exactly what you're describing?
            Also, I don't have multiple faces. I have a single face, and I want these entities grouped together, then placed under model.entities -> rootGroup -> groupGroup.
            EDIT: "newRootGroup" -> "newGroupGroup" in 2nd paragraph...
              I must assume faceEntities is in the same context as the rest.
              But in newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)
              where did groupGroup suddenly come from ? It's not referred to in your example code...
              and IT must be inside the rootGroup.entities - BUT where'd it come from...
              THEN you explode this probbaly non-existent thing == Bugsplat ???
              You seem to have overcomplicated it...
              Also simply saying group2=group1 is changing a reference - it doesn't transfer 'properties' or 'attributes' - so you need to get the original group2 name and give that to the group2, and the same with layers, materials etc etc...
              As I said tgroup=ents.add_group(extggroup,facebits)
              'remember' extggroup details first, then
              extggroup.explode
              you have now got the entities that were in 'extggroup' AND 'facebits' inside the same group...
              Now re-refer to tgroup as extggroup and add the 'remembered' extggroup details to []what is now 'called' extggroup ...
                draftomatic
                faceEntities is under model.entities. rootGroup is under model.entities. groupGroup is already under rootGroup (look at the screenshots!). In fact, I created groupGroup with rootGroup.entities.add_group() (I'm 100% sure that groupGroup is correct; I can even find it by searching rootGroup.entities.each())
                How?
                I AM doing this. Look at the comments in the example code. The only purpose of groupGroup = newGroupGroup is to keep my variable names, since in the real code these are instance variables.
                extggroup.explode
                Why do I have to store these properties? Consider this:
                ` newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)
                I don't see anything wrong with copying the properties directly before I explode groupGroup. The properties are going from groupGroup to newGroupGroup, so at one point they will have identical properties. Then I explode groupGroup. Seems okay to me...
                  Last things first...
                  Assuming the next two objects mentioned are in the same 'context'...
                  A group variable ' group1' is named "mygroup1", it's on layer "XXXX" and has material "red" etc. This is the group we are adding to
                  A group variable ' group2' is named "mygroup2", it's on layer "AAAA" and has material "banana" etc. This is the group we want to add.
                  You add a temporary group thus:
                  newgroup=group1.parent.entities.add_group(group1,group2)
                  At this point variable ' newgroup' has name="", layer=nil and material=nil etc.
                  When you explode 'group1' all of it properties and attributes vanish with it [properties reside with the object NOT its variable]... UNLESS you save the properties/attributes BEFORE you do the explode thus:
                  name=group1.name layer=group1.layer mat=group1.material
                  etc
                  NOW you can explode group1, change its referring variable to the temporary group...
                  group1=newgroup group1.name=name group1.layer=layer group1.material=mat
                  etc
                  NOW for all intents and purposes the group is still group1 [its 'id' has changed but nothing else].
                  So you end up with a group variable ' group1' named etc exactly as before containing the same entities PLUS ' group2'...
                  You can also explode group2 if desired...
                  You say faceEntities is under model.entities. rootGroup is under model.entities. groupGroup is already under rootGroup...
                  BUT newGroupGroup = rootGroup.entities.add_group(groupGroup, faceGroup) [note the removed () after entities - not correct !!!] will add a group to rootGroup's entities, and remember that at this point in your code rootGroup is now a pointer to what was newRootGroup... which you have just made inside @model.entities from the original rootGroup and [ruby:1upcmdm6]faceGroup[/ruby:1upcmdm6].
                  You are therefore adding two things into this [ruby:1upcmdm6]newGroupGroup[/ruby:1upcmdm6] ... [ruby:1upcmdm6]faceGroup[/ruby:1upcmdm6] which IS in there as you have just added it AND the mysterious [ruby:1upcmdm6]groupGroup[/ruby:1upcmdm6] BUT newRootGroup [now referred to a rootGroup] was made from [ruby:1upcmdm6]faceGroup[/ruby:1upcmdm6] AND rootGroup which you then exploded after it was added - so unless [ruby:1upcmdm6]groupGroup[/ruby:1upcmdm6] was already inside that and is therefore now inside the now called rootGroup after the explosion, AND you had previously referred explicitly to it BEFORE all of this - which is NOT shown in any of your code πŸ˜’ - then it WILL fail - if you have made a reference to an 'object' that seems to have appeared from nowhere and therefore ==nil.
                  Do you have a handle to this 'object' set up before this code snippet ?
                  You are perhaps onfusing the groups' references [variables] and their actual names [which appear in the Outliner]... So it may be named 'groupGroup' but is there a variable called 'groupGroup' that is pointing at it ?? There's nothing in your code to show it...
                  Try tidyinh your syntax [remove unneeded () etc] and check that everything is properly 'referred to' by variables -
                  which can share the objetc's names but need to be called explicitly.
                  Also note that making a new group [unlike making a copy of it] defaults all of its properties/attributes - and you have to transfer them to its 'clone'...
                  πŸ˜’
                    draftomatic
                    TIG, I really appreciate your help, but I still can't see that I'm doing anything wrong.
                    I've made a small example script that emulates my bug. Could you take a look please please? πŸ˜ƒ
                    test_group_bug.rb
                      Try this...
                      # Testing group nesting
                      ### with TIG edits ###
                        model = Sketchup.active_model
                        entities = model.active_entities ### NOTE; 'active_'
                        pts = []
                        pts[0] = [0, 0, 0]
                        pts[1] = [100, 0, 0]
                        pts[2] = [100, 100, 0]
                        pts[3] = [0, 100, 0]
                        face = entities.add_face(pts)
                        faceGroup = entities.add_group(face)
                        faceGroup.name = "faceGroup"
                        ### A GROUP REFERRED TO AS 'faceGroup', NAMED 'faceGroup'.
                        ### IT CONTAINS THE FACE AND ITS EDGES - THEY ARE COPIED IT THEY ARE
                        ### STILL NEEDED IN THE ORIGINAL ENTITIES...
                        rootGroup = entities.add_group()
                        rootGroup.name = "rootGroup"
                        ### A GROUP REFERRED TO AS 'rootGroup', NAMED 'rootGroup'.
                        newGroup = rootGroup.entities.add_group(faceGroup)
                        newGroup.name = rootGroup.name
                        ### THERE'S NOW A GROUP REFERRED TO AS 'newGroup', BUT CALLED 'rootGroup'
                        ### INSIDE IT IS A GROUP REFERRED/CALLED 'rootGroup'
                        ### WHICH CONTAINS A GROUP REFERRED/NAMED 'faceGroup'
                        ### WHICH CONTAINS THE 'face' ENTITIES...
                        ### NOW DO WHAT YOU WANT...
                        draftomatic
                        @tig said:
                        Try this...
                        Try what? I did all of this in my code! I also want to nest faceGroup one level deeper, into "groupGroup."
                        As I said, getting faceGroup inside of rootGroup isn't a problem. It works using your trick. But I need it to go one level deeper, into groupGroup, and it's not working!!!
                        You stopped the code RIGHT BEFORE the point where I don't know what's wrong... And you took out the part with groupGroup, which is my entire problem!
                        Your code does this:
                        Please TIG or someone else, can you tell me specifically in my code, i.e. what line and WHY, am I doing wrong? I posted the example which reproduces my bug. What am I doing wrong? This bug has been stopping me for a week now... it's getting ridiculous!
                          This 'groupGroup' must be inside the same context as 'faceGroup'... OR...
                          You already have
                          rootGroup** IN model.entities
                          AND
                          face IN faceGroup IN newGroup [also named 'rootGroup'** BUT it is a different group] IN model.entities
                          so simply use:
                          groupGroup=newGroup.entities.add_group(faceGroup)
                          groupGroup.name="groupGroup"
                          face IN faceGroup IN groupGroup IN newGroup [named 'rootGroup'**] IN model.entities
                          OR you add another a group to model.entities
                          groupGroup=entities.add_group(newGroup)
                          groupGroup.name="rootGroup" ###***
                          face IN faceGroup IN newGroup [named 'rootGroup'] IN groupGroup [named yet another 'rootGroup'*] IN model.entities
                          You just have to decide which groups contain which.
                          Naming groups with the same name is plain confusing - why do it ?
                          Give them each a unique reference and at the end name them appropriately...
                            draftomatic
                            Okay, you're just confusing me now, and what you're describing doesn't work for my situation. groupGroup already exists, and rootGroup already exists. I'm only creating them again in my example so that it can stand alone. So doing anything like groupGroup=newGroup.entities.add_group(faceGroup) isn't acceptable, because groupGroup is ALREADY THERE.
                            Look TIG, can we get a bit simpler? Can you look quickly at test_group_bug.rb? I just simply don't understand why this line:
                            LINE 49: newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)
                            is breaking my code. As far as I can see, this is EXACTLY what you've told me to do. The contexts of groupGroup and faceGroup are identical (faceGroup.parent = rootGroup, and groupGroup.parent = rootGroup... I've checked).
                            Moreover, the SAME CODE works several lines up, when I do the SAME THING, except in model.entities instead of in rootGroup. I'm very confused, and I need a straightforward answer. What EXACTLY is wrong about that line of code?
                              The 'groupGroup' group DOESN'T really exist... except that you have made an empty group [too early] with that reference.
                              Adding that empty group so early on into the mix and then trying to 'move' it into another group only confuses things.
                              IF you already have a non-empty group with that reference then it's OK... but if not only make it when you need it otherwise.
                              If you still can't get your head around this then please post a simple before and after set of uniquely named objects with their hierarchy - e.g.
                              modelEntities=model.active_entities
                              CONTAINING [at least] groupX [an existing group that isn't empty] and face [a face]
                              OR ANY OTHER entities set with common objects you are to 'group' ?
                              groupX > modelEntities
                              face > modelEntities
                              WHICH BECOMES faceGroup = modelEntities.add_group(face)
                              face > faceGroup > modelEntities
                              THEN group1 = modelEntities.add_group(faceGroup, groupX)
                              face > faceGroup > group1 > modelEntities
                              groupX > group1 > modelEntities
                              THEN group2 = group1.entities.add_group(faceGroup, groupX)
                              face > faceGroup > group2 > group1 > modelEntities
                              groupX > group2 > group1 > modelEntities
                              THEN group3 = group2.entities.add_group(groupX)
                              face > faceGroup > group2 > group1 > modelEntities [STILL THE SAME AS BEFORE]
                              groupX > group3 > group2 > group1 > modelEntities
                              TO SEPARATE THE ENTITIES INTO SEPARATE GROUPS ETC ETC...
                              YOU CAN GO ON AND ON...
                              This has no 'names' just references to groups etc - you can add those later...
                                draftomatic
                                In my real code, there is already a CPoint inside "groupGroup." If you think it's a problem that groupGroup is empty, then fine, I just tried adding a CPoint to groupGroup in my example script. Still broken.
                                Sir, my head is wrapped around this problem about 9 times already. I feel like you think I don't understand, but I do. I understand every word you have written, and I keep telling you, "I'm doing that, I'm doing that. Look at my code, look at my code."
                                I did this already. Look at my script!!! Look at my screenshots!!! I am creating rootGroup and groupGroup. That is my hierarchy.
                                I'm going to repeat my question again. What is wrong with line 49 of my previous example script? I COMPLETELY understand EVERYTHING you're telling me, and I believe I'm doing it, but it's still broken, and I don't see why!!!!!!!!!!
                                  Aaargh... in your sample code you 'magick' a group out of 'thin air' [groupGroup] and then you add it into a group within a nested group. IF that does exists it certainly isn't inside the 'newRootGroup' [retitled 'rootGroup'] entities as you've just created that - so it will ultimately splat - you ARE cross-threading entities.
                                  Please try recasting your code [ignoring names and reusing references [variables] as it's getting confusing] in a way I outlined...
                                    draftomatic
                                    I think TIG gave up on me... 😳
                                      draftomatic
                                      @tig said:
                                      Aaargh...
                                      Argh indeed!
                                      Here it is - as simple as I can make it. This is 14 lines of code. Now tell me, what is wrong?
                                      The heirarchy is: model.entities -> group1 -> group2
                                      After the code finishes, it should be: model.entities -> group1 -> group2 -> faceGroup -> face+edges
                                      You can see that I'm creating these groups here, so there's no "magick!"
                                      ` # Testing group nesting
                                      modelEntities = model.active_entities
                                      Create a face
                                      pts = []
                                      pts[0] = [0, 0, 0]
                                      face = modelEntities.add_face(pts)
                                      Create root group
                                      group1 = modelEntities.add_group()
                                      Nest group2 inside group1
                                      group2 = group1.entities.add_group()
                                      Create group for faceGroup
                                      Nest in the first level
                                      newGroup1 = modelEntities.add_group(group1, faceGroup)
                                      group1.explode()
                                      Repeat to get it to the second level deep
                                      newGroup2 = newGroup1.entities.add_group(group2, faceGroup)
                                      group2.explode() # This crashes SketchUp`
                                      • Chris FullmerC Offline
                                        You are exploding group1 though. That does seem right to me. I can't look at it right now, but I probably can try later tonight.
                                        Seems like you should make a group and add the face data to it. Then make a group and add the facegroup to it. Then make a new group and add the other group to that. I'm sure that is exactly what you've already tried. I'll see if I can write up a fully working sample (unless someone else beats me to it).
                                          draftomatic
                                          Thank you very much Chris. And thanks to TIG too, even though I'm pretty sure he's moved on to bigger and better threads than this =D
                                            draftomatic
                                            Check it out. I have all these groups (group2 - groupN), under a root group (group1). And then I have faces, which I want to group with edges (faceGroup), and place in a nested group (group2 - groupN). There could potentially be many faceGroups, as shown in the picture...
                                            HOWEVER... my example script 2 posts up is a simplified version of this, with only one nested group (group2), which is initially empty.
                                            Clear enough? πŸ˜ƒ
