    Permanent Window Cut Plugin?
    34 Posts 10 Posters 7.0k Views 10 Watching
      DoubleCut ๐Ÿ˜ฒ ๐Ÿ˜•
      walks off to a corner, huddles up rocking
        I know that tt and I are working in parallel - and parallel lines never meet!
        Several others - including Didier have also had ago and given up... ๐Ÿ˜’
        • utilerU Offline
          utiler
          This has been a feature request for future SU releases I don't know why it hasn't been taken seriously by Google. During 3D Basecamp a few weeks ago I discussed just this with a few Googlers and pointed out that with the inclusion of solid tools in V8 it makes sense that this should be the next step.
          I am aware we are talking about two different things in solids and components but there are similar outcomes.
          Assume 100mm walls are modeled and grouped. chose component [door/window, DC even...] and select insertion point. Ideally the component will be created to suit 100 thick walls so when inserted both wall planes are cut at the reveals.
          Move the window and the reveal moves with it. Edit the DC attributes to change height of the door and the reveal changes with it. Remove the door and the wall planes clean up....
          If this could be done, it would take SketchUp into a new dimension IMO.
          Just Curious...
            I have decided to work on it 'now' [rather than later]... already it's better than the 'base-tool' - e.g. the reveal faces now match the inner face's properties...
            Watch this space - or its sibling thread............
              That's great news, a much needed tool
                Ay yes the famous line 186 makes the trick ๐Ÿ‘
                http://d9.img.v4.skyrock.net/d97/stock-car-du-sud/pics/1357430234_small.jpg
                ๐Ÿ˜‰
                  Edit ๐Ÿ˜ฎ
                  Yes you can copy it on the same face, but not on another perpendicular face! ๐Ÿ˜•
                  Glue is losted again ๐Ÿ˜’ ๐Ÿ’š
                  • EarthMoverE Offline
                    EarthMover
                    Quick vid using component punch and 1001bits to make windows with mini blinds. http://www.screencast.com/t/MTU5NDAw
                    Content Creator at Skapeup
                      Edit
                      Curious this morning all woks fine with the line 186 ๐Ÿ˜ฒ โ˜€
                      http://forums.sketchucation.com/download/file.php?id=54488
                        My new 'Hole Punch Tool' v1.0 is now available here http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                        • utilerU Offline
                          utiler
                          Interesting, Earthmover. what did you do at the 51st second mark of the video? seems you selected a tool to remove the back face where the window punches through the wall....??
                          TIG - loading your ruby now. This is really going in the right direction!!!
                          I can't recall such an important step with SU.....
                          Just Curious...
                            EarthMover
                            Andrew, I just selected the windows and ran the Component Punch plugin that was posted earlier in this thread.
                            • utilerU Offline
                              utiler
                              Cool, ta. I obviously haven't tried it yet.... ๐Ÿ˜ณ
                              Just Curious...
                              • Bob JamesB Offline
                                Bob James
                                Just stumbled upon ComponentPunch:
                                • 2 / 2
