    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Architect Tools
    119 Posts 32 Posters 157.4k Views 32 Watching
      This is a painful known issue with first version of v2013, with random problems with new toolbars seemingly 'invisible'...
      It is probably stuck underneath a docked toolbar or two in the top bar.
      Drag the top bar toolbars off so they are floating, and if you see the required toolbar below then double-click it a few times to try and 'unglue' it.
      Then you should be able to drag it off so it's floating, and then relocate it where you want...
      Then relocate the moved toolbars as desired.
      It that doesn't work there is a registry hack... I've posted that in a few threads... do a search...
        sepo
        thanks Tig....it worked. It was hidden behind top tool bars....how bizzare.
        However shadow fix toolbar is nowhere to be found....
          When a new plugin makes a toolbar for the first time it ought to be made floating in the top left quadrant of the screen. That is the default. Scripters can't affect how it works. But for some yet to be fathomed reason SketchUp 2013 occasionally decides to dock it in the top-bar, which would be so bad BUT it puts it under existing toolbars - which isn't allowed as docked toolbars must always have their own 'space' πŸ˜’
          I know Trimble are striving to fix it - it's an embarrassing glitch...
          • I Offline
            isbelcia
            I use Sketchup 7 and I want to install architect tool. My question is how to install the necessary TT_lib2.rbz on sketchup version lower than 7?
            Thanks Iza
              @isbelcia said:
              Thanks Iza
              To Auto-Install the contents of a RBZ you need v8M2 or newer.
              Assuming the plugin will work in say v7 [many do] then you can use the old-way...
              Change the filetype suffix from the .RBZ file to .ZIP.
              An RBZ is actually a ZIP with another ending.
              Extract the ZIP's contents to a temporary folder, you should have a loader rb and a main folder, within that keep all of the files within their respective subfolders etc, where applicable. NEVER move files out of the subfolder that they are shipped in...
              Before installing the plugin - as an Admin, ensure you have FULL read/write permissions set for all users/groups listed in Properties > Security > Edit...
              NOW move the contents of the temp folder - in this case the TT_Lib... folder with its subfolders intact and its 'loader' rb into the Plugins folder...
              Restart SketchUp...
              • tt_suT Offline
                tt_su
                Installing Plugins for SketchUp
                Update: June 2014 This article was written right before Google sold SketchUp to Trimble. Since then the instructions has changed slightly. In May 2013 SketchUp 2013 was released which included the …
                Procrastinators Revolt! (www.thomthom.net)
                  rv1974
                  Thomthom, would it be possible to add some tiny but important option to flatten entities by current UCS (not only restricted to the World XY plane as we got it now)?
                  I did not quite followed the changes in you politics concerning your tools maintenance after relocation to Olympus. Hope it sounds relevant to you now.
                  Thank you in advance.
                  • KrisidiousK Offline
                    Krisidious
                    I think that function is covered by JQS Align.
                    By: Kristoff Rand
                      rv1974
                      this one:
                      http://sketchucation.com/pluginstore?pln=jsAlign
                      it won't work with user defined direction of flattening unfortunately.world UCS axis only.
                        becker84
                        bug splat in sketchup pro 2016+win 10 pro x64... 😞
                          How can you reproduce that?
                          • romboutR Offline
                            rombout
                            Is it possible to add hover/tooltip info? When i havent used it in a while i tend to forget some icons πŸ˜„
                              No tooltips are showing up? What OS are you on?
                                becker84
                                I do not know what caused it, but I know I did the test by removing the plugin and the problem disappeared, when I put the plugin again the bug splat appear!
                                  applemango85
                                  hi
                                  I'm having a problem flattening my cad import. Ive made faces but whatever I do I can't flatten this part of the road. Ive tried this app but still no joy.
                                  any tips on this type of problem
                                  cad model coming in not flat.skp
                                  • PixeroP Offline
                                    Pixero
                                    There is a easy manual way of flattening anything.
                                    Set camera to top view.
                                    Set camera to parallell projection.
                                    Export as 2d dwg.
                                    Import that flat dwg again.
                                    Done.
                                    • boofredlayB Offline
                                      boofredlay
                                      Export as 2d dwg.
                                      Done.
                                      Simple and effective.
                                      • jujuJ Offline
                                        juju
                                        Export as 2d dwg.
                                        Done.
                                          applemango85
                                          That is genius pixero - I totally forgot about that method.
                                          the only thing is that for some reason it scales at 1/10th scale but thats a really easy sort
                                          • 6
                                          • 6 / 6
