    [Plugin] TT_Lib²
    310 Posts 66 Posters 438.7k Views 66 Watching
      No, it's a new version, but v2 isn't compatible with v1. Hence v1 is still possible to download. I know it's confusing, I might just bundle v1 with Selection Toys and be done with it, as ST is the only plugin that uses v2.
        billrivas
        after I put this folder to plugins folder it´s all solved;
        Very Nice plugin!! Thanks man!
        • daforumD Offline
          daforum
          Hi. I've downloaded TT_Lib2 as I want to use QuadFaceTools_0.6.0 in SU7.
          Do I need to install the TT_Lib2 folder with all 50 items that are in the TT_Lib2 folder into the Plugins folder?
          Many thanks
            Many thanks
            If you're unsure on how to install the plugin I'd advice you to use this utility:
            http://sketchucation.com/forums/viewtopic.php?t=42315
            • daforumD Offline
              daforum
              Hi thomthom.
              I had a look at the link and it says the utility is for SketchUp 8M2 or newer
              (i'm on SU v7 Mac)
                Upgrade to v8
                  @daforum said:
                  Hi thomthom.
                  (i'm on SU v7 Mac)
                  Are you using Pro?
                  If not, then I'd also recommend you upgrade to version 8.
                  To manually install you'd need to ensure the files are located in such a manner indicated by the footprint description:
                  A general guide can be found here:
                  http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                  • daforumD Offline
                    daforum
                    Thank you, I will eventually upgrade to 8. I will have to do it manually.
                    Do I still need to install all 50 items in the TT_Lib2 folder?
                      Yes, all content in the TT_Lib2 folder needs to be intact. Lots of them depend on each other.
                        matt.gordon320
                        Thanks for the awesome update thomthom!
                        • david_hD Offline
                          david_h
                          Thanks. I have that and I have run the little installer as well.
                          It's going now. thank you.
                          You see. . this is why I really shouldn't be wearing the green badge. 😳
                            I've been making it easier with my newer plugins, they will open a webdialog with a direct link to where to download.
                              dmitryzhuikov
                              Hi everyone. I'm stucking in installing TT_Lib2, somehow i don't have "Install Extension" button.
                              I'm using Sketchup 8 Pro, on win7. Thanks in advance
                              Link to screenshot:
                              http://letitbit.net/download/78848.7e37f4354d9034a91368ed6e3283/1212.JPG.html
                              • massimoM Offline
                                massimo Moderator
                                Maybe you don't have the latest SU8 version?
                                  dmitryzhuikov
                                  Ok, will try with latest
                                  • P Offline
                                    petrusyap
                                    Hi.. I wonder why whenever I try to install TT_Lib2 2.7.1 into my sketchup 8 Pro, its always stated as 2.6.0 version. The CleanUp3 plugin cannot be used due to that issue. Please help.
                                      Please fill out your profile information with OS and SketchUp version.
                                      Since I don't know what OS you have I have to guess - but I'm guessing you have Vista, Win7 or Win8. And you might have UAC enabled - which can restrict access to your plugins folder.
                                      Some files might have ended up in VirtualStore. Install this utility and use the "Check VirtualStore" menu under Plugins. http://sketchucation.com/forums/viewtopic.php?t=48399
                                      If there are files in the VirtualStore you should move them to the real plugins folder. And you will need admin rights to do so.
                                      Otherwise I'd recommend you manually remove the old TT_Lib and install the new one.
                                      Oh, btw - note that RBZ files is not the same as RB files. You need to use the "Install Extension" button to install RBZ packages. Just copying a RBZ file to the Plugins folder will not work.
                                      • P Offline
                                        petrusyap
                                        Hi Thom, thanks for the prompt reply. I am using Windows 8 Pro 64bit edition and have the UAC disabled. I use the install extension from the Preference >> Extensions menu to install the rbz files and but the system always identified the plugin as 2.6.0 when i try to use Libfredo Check For Plugin Update feature. But i will try the VirtualStore plugin as you suggested. Will keep u updated in minutes. Thanks
                                        • P Offline
                                          petrusyap
                                          Hi Thom,
                                          The error still remain the same. I try download the TT_Lib2 2.7.0, 2.7.1 and 2.8.0 from the BitBucket as well but still detected in the system as 2.6.0. Shall I try to re-install my SketchUp? Installed the VirtualStore Plugin, if i clicked on the Check Virtual Store, the windows automatically direct me to the sketchup plugin folder. Is it done correctly? Thank you
                                            No - if it opened a folder it means it found files in the VirtualStore folder.
                                            Observe the full path to the folder opened in Explorer. If there was no files in VirtualStore you should have just gotten a messagebox.
                                            Also, when you navigate to the actual Plugin store you should see a button in Explorer "Compatibility Files". This is also an indication of files in VirtualStore.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 15
                                            • 16
                                            • 8 / 16
