    Removing shadows from an image
    8 Posts 3 Posters 1.9k Views 3 Watching
    • utilerU Offline
      utiler
      Guys, Need advise quick. See attached image. I need to change the color to white and apply it to a cabinet front to show a client at a meeting this afternoon.
      Any idea how to remove, balance or blend the shadows that show from the right-hand side?
      Thank you thank you!!
      Just Curious...
      • jeff hammondJ Offline
        jeff hammond
        is this the largest size you have? it'd be easier to work with if it were bigger..
        here's a quick hack job to show what you're after is possible.. if this is the only size you have, i'll attempt a cleaner version with it..
        oh, and do you have photoshop? if so, i'll explain what i'm doing.. i don't know how to do it with a different image editor.
        dotdotdot
          I did two hack jobs. If Jeff's doesn't work, would mine?
          And here's the second one almost seamless.
            jeff hammond
            oh, i'm going to refrain from attempting a second version btw. πŸ˜†
            dave's are probably exactly what you're after
            dotdotdot
            • utilerU Offline
              utiler
              Geez, you blokes are good!
              I use GIMP Jeff which i assume is almost the same as PS... How did you do it Dave? I think that will be just right...
              πŸ‘ πŸ‘ [one each] πŸ˜‰
              Just Curious...
                Jeff, you should go ahead and try. Mine aren't really that good.
                Andrew, I have Photo Shop Elements and I used Enhance>Adjust Lighting to try to even out the highlight side and the shadow side. Then I converted the image to black and white and adjusted the Red intensity slider up a little bit. To be honest, there's probably a better way. I'm only just learning how to use PSE and had never done this before. Purely beginner's luck. 😳
                • utilerU Offline
                  utiler
                  cool thanks Dave. I have to get better at editing graphics.....
                  Just Curious...
                    You're welcome. I do, too.
