    Plugin Facegroup [triple resolved]
    9 Posts 3 Posters 1.7k Views 3 Watching
      Seems Facegroup by Gavvy don't works fine 😞
      Does exist another plug who transform a selection of 6 faces on 6 groups ?
      (for a simple cube) or any selections of x faces in x groups?
      • thomthomT
        Errors? Crashes? No menu items?
          When you select only faces of a cube (or all edges + faces) only up and down faces are transformed in groups !
          Cube created by a face Pushpulled
          And the plug "works" is given for only the V6 but works in same way for the V7 ! πŸ˜„
          • thomthomT
            With the Ruby Console open - do you get any errors?
            • thomthomT
              There's an odd line in the code: next if f.normal.z == 0
              Comment that one out and it appears to work.
              However - there might be other issues - it iterates the selection which is modified as it groups faces.
              To be safe, here's a modded snippet:
                ss.to_a.each {|f|
                  next unless f.is_a?(Sketchup;;Face)
                  #next if f.normal.z == 0
                  model.active_entities.add_group(f)
                Absolutly no error with the ruby console!
                Just result is half "false" : only up and down faces are an invidual group!
                Seems common "edges, faces" make the false result πŸ˜„
                have you same result than me? (here in mode XRAY in V6, it's the same in V7)
                  Many thanks!
                  Else I have found Make_components by Matt66 at Crai Ruby depot! β˜€
                  • TIGT
                    Many thanks!
                    This simple one-liner makes each face in the selection into a separate group
                    m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|n.add_group(e)if e.class==Sketchup;;Face}
                    You can use it as the basis of a new tool......
                      @ TIG: Works fine! 😎
                      So A third solution β˜€
                      I must change the title and my other post! πŸ’š
                      Line above by TIG, Grow by TIG, Radial Move by C.Plassais πŸ˜„
