    Roof Help!
    6 Posts 5 Posters 543 Views 5 Watching
      Dragoonprogramming
      Hi guys,
      I am working on a custom home for a contractor however I need help with the roof as it is very complicated
      Can somebody help me with this?
      Taylor
      "...And if he says that one more time i'll punch him right in the throat" - Armstrong and Getty
      My website http://dragoonprogramming.weebly.com/
        d12dozr
        This will get you started, if you need more help just do a search on this forum or Google for the basics, and if you have a specific question, then come back here with that.
        YouTube - SketchUp: Complex hip roofs and the Follow Me tool
        [flash=480,385:lgd45m2j]http://www.youtube.com/v/A6WxE6oO3JU?fs=1&hl=en_US[/flash:lgd45m2j]
        http://goo.gl/f7ooYh
        • david_hD Offline
          david_h
          That's a great technique. i was doing that before I knew Aiden had a video on it. The only thing I would add is
          Make the Roof a group unto itself to make the Erasure process a little easier.
          D
            Import the image, draw over it [keeping equal sides and using rectangles etc]draw verticals at ridges and draw hips etc...
            • bmikeB Offline
              bmike
              are you building a shell model only? or interiors... different approaches depending on end use of model / images.
              i usually build it flat on the ground, then clean it up and raise it into place, separate from walls and etc.
              same pitch, same overhang, same plate height everywhere?
              that's eas(ier)... lots of ways to do it.
              mike beganyi design + consulting llc
                Dragoonprogramming
                Finished 😍
                Thanks guys realy helped I am geo modeling this so it is going to be basic! Roofs are not my forte...
                As a reward for helping me out you can see how far I have gotten πŸ˜„
