    [Plugin] Fix Reversed Face Materials
    Scheduled Pinned Locked Moved Solved Plugins
    83 Posts 26 Posters 124.3k Views 26 Watching
      The tool works for any faces - as long as they only have a material on the back and not the front.
      It simply reverses the face whilst leaving the materials in the same 'location' [orientation].
      With an 'un-fixed' face - flick between Textured Mode and Monochrome Mode to reveal faces that are 'wrongly' oriented but have their materials on the back so look OK in the SKP-render BUT will fail in the external-renderers.
      With a face that's 'fixed' it looks the same in the SKP 'Texture Mode', but it will then render properly in renderers [the Monochrome Mode should then show all faces oriented the same]
        Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=264134#p264134
        It has an additional Tool 'Reverse Faces and Materials' - this reverses faces keeping their materials with correct UV-mapping - effectively turning the form 'inside out': if it is 'brick' outside and 'wood' inside with the 'back-faces' oriented to the 'outside', then using the tool reverses the faces so that the back-faces are oriented to the 'inside', AND now the 'wood' material will be on the 'outside' and the 'brick' material will be on the 'inside' - UV-mapping will have been correctly reapplied.
        For example I recently had an imported OBJ object that had all some objects with faces reversed ['blue' outwards] and so their materials were mapped [correctly] on their 'insides'. Simply 'reversing' the faces failed to keep the UV-mapping on the new face orientations [on 'smoothed' surfaces it's especially problematical] - but this tools now solves that problem.
        The included lingvo files have all been updated to match the changes.
        • P Offline
          pmolsen
          @tig said:
          Note: Groups and Component-Instances that can have materials applied
          directly onto them - then any faces within them that have the default-
          material [front and/or back] will then appear to have that material applied
          to them. In fact these faces within the Group/Definition will still have
          the default-materials [front and/or back]. If you want to quickly remove
          the appearance of this material on the back-faces within the group then
          explode the group and immediately regroup the geometry - the group's
          previous material will then be individually transfered to each face that
          had the default-material. Now use this 'Delete Back-Materials' to delete
          the unneeded back-material.
          Excellent plugin! Exactly what I have been waiting for.
          I think I must be missing something with your above comment though. As you say if a group or component is textured with a material without first opening the group or component, all untextured faces, including the back faces, appear to be painted with that texture.
          To fix the problem there is no need to ungroup and regroup as stated above. Simply select the default texture (either from the materials window or by sampling an untextured front or back face) then paint the unopened group or model. All untextures faces go back to untextured the way they should be.
          • P Offline
            pmolsen
            When I start Sketchup after installing the plugin I get the following error:
            Error Loading File FixReversedFaceMaterials.rb
            No such file to load -- deBabelizer.rb
            I checked the zip file and there is no such file in it. I found a copy in the Lattice Maker plugin but it should really be in this one as well.
            Also what is the Sketchup8 link that is installed in the subfolder?
              Sorry about this... it is always the same 'deBableizer.rb' file... BUT I have now added it to the zip [ http://forums.sketchucation.com/viewtopic.php?p=264134#p264134 ] - it was packaged with the earlier zipped versions, but I missed it out of this one 😳
              I also managed inadvertently to add a shortcut linking to my copy of SUp v8 [luckily it's all public now anyway] - but that's now gone too !!! I just had a really bad day πŸ˜’
                Aerilius
                No problem, that shortcut was not dangerous πŸ˜„
                Many thanks, this is the best reversed-faces-plugin that I ever found πŸ‘
                I saw, maybe you'd like to have a german translation πŸ˜‰
                new german translation
                  Thanks for the DE lingvo.
                  I'll include it in any future release - unless someone else wants to jump in with another version or comments...
                  My German is not up to much [as you probably noticed!]... πŸ˜‰
                    Here's a tweaked German lingvo file [by Aerilius]...FixReversedFaceMaterialsDElingvo.zip
                    • E Offline
                      Ecuadorian
                      Thank you, TIG!
                      This is a life saver... πŸ‘
                      -Miguel Lescano
                        Here's another version of the DE lingvo [by User2012] - try them and choose which you want...FixReversedFaceMaterialsDE.zip
                        • E Offline
                          Eugenegoth
                          Thank you TIG!!!!
                            Any chance this could be compiled under a menu? πŸ˜•
                              No sooner said than done - here's v1.5 with the four tools under one submenu http://forums.sketchucation.com/viewtopic.php?p=264134#p264134
                              πŸ€“
                                Thanks πŸ‘
                                I've a file that doesn't remove backface materials πŸ˜•
                                  Thanks πŸ‘
                                  Let's see it - PM if needed...
                                  Is it perhaps a group/instance where the back face is actually the default material but is displayed in the container's material ? πŸ€“
                                    Too large for here. I'll email it.
                                      Got it.
                                      Where are the errant back faces with materials ?
                                        Fixed it and emailed back to you... a material was applied to some group/instances, I used the Outliner and Entity Info to make it the default-material, then re-ran the tool to remove all back-face-materials - it seems OK now ?
                                          JGA
                                          Regards,
                                          JGA
                                          • irwanwrI Offline
                                            irwanwr
                                            i might have a problem with the new version 1.5 20120216.
                                            i don't know why and not sure either.
                                            the last time i used this plugin, it can be accessed in context menu by right clicking.
                                            but it seems that the new version would only available in the toolbar menu instead.
                                            i just overwrite the previous version when installing this new one.
                                            • 2 / 5
